Duster auto to 4 speed column #571994
01/04/10 02:33 AM
01/04/10 02:33 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
I'm converting a '73 Duster column shift auto to a floor shift 4 speed. What can I do with the column to get rid of the auto shifter? I live in New Zealand & it was a major mission to get a set of Duster 4 speed pedals so I don't want to go through that again getting the correct column.
Does anyone make a lower hub/ring for the auto column that replaces the shifter hub/ring?
Re: Duster auto to 4 speed column [Re: nz383man] #571995
01/04/10 04:55 AM
01/04/10 04:55 AM
Re: Duster auto to 4 speed column #571996
01/04/10 05:19 AM
01/04/10 05:19 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
https://board.moparts.org/ubbthreads/showflat.php?Number=4960512
Cheers for that, the part at this site looked very good although our '73 has the ingition in the mix as well.
http://www.forabodiesonly.com/mopar/showthread.php?t=55637
Re: Duster auto to 4 speed column [Re: nz383man] #571997
01/04/10 05:39 AM
01/04/10 05:39 AM
I'm in the same boat with my 73 but I will probably make something up or patch it unless something "cheap" comes along.
The car was free so I can't complain, a BB A body!
Re: Duster auto to 4 speed column #571998
01/04/10 06:27 AM
01/04/10 06:27 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
A BB A body for free sounds like a great deal, what are your plans for it?
I was thinking about leaving the gear indicator housing but strip it out & maybe rig up a shift light inside it.
The lower ring with the shifter I would either grind off & fill or replace with a home made piece (I'm a machinist) but rather than re-invent the wheel I thought I'd ask what everyone else has done.
Re: Duster auto to 4 speed column [Re: nz383man] #571999
01/04/10 06:42 AM
01/04/10 06:42 AM
I got a 400 to stroke out to either a 470 or 500, haven't decided which yet. Patch up the body as I don't want a show car just a nice driver.
