Re: Need advice on milling heads on a '73 440.
[Re: 74fldart]
#570891
01/03/10 02:15 PM
01/03/10 02:15 PM
DaytonaTurbo
Manitoba, Canada
figures vary but compression would be around 8 to 1 maybe lower for a 73 stock 440 unless its considered a hp 440, but i think they were gone by 73 .
HP 440 was still around longer, however HP 440's used the same pistons are regular 440's. So in the 70's a 440HP had the same 7.8 CR as the regular 440's.
[Re: DaytonaTurbo]
#570893
01/03/10 02:21 PM
01/03/10 02:21 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
There is a formula telling you how much to mill the intake flange on the heads per thou of head milling, I don't know what it is though.
taking the BB heads chamber volume like: -66.5/73.5cc as closed chambers -79/81/83cc ( yeah right, really 88 to 92 cc ) as open chambers
[Re: NachoRT74]
#570894
01/03/10 02:32 PM
01/03/10 02:32 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I find there are too many downsides to head milling. A clean up is ok but to raise compression ratios due to low piston heights it's a bunch of cutting for little gain.
Intake bolts hard to line up, valley pan not fitting properly which equals oil sucked into intake ports and will usually create pushrod length problems.
My choice would be to buy new pistons.
[Re: 65dodgebob]
#570896
01/03/10 02:52 PM
01/03/10 02:52 PM
NachoRT74
Valencia, España
.0123 is stated by Direct Conection books.
.042 of head will reduce 1cc volume as far keeping on open chamber section.
Yeah pistons is better but 400 doesn't have too much options off the shelf. So mill is a handly solution to help. 440s have lot of options though
Even better, aftermarket heads too
depending on what you want to get of course will be entering on troubles or not
[Re: timinator]
#570901
01/03/10 03:53 PM
01/03/10 03:53 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
...I was eventually planning on pulling the engine in a couple years for a proper rebuild with a stroker crank...
Since you plan to build it right at a later date, just bolt it together and run it.
[Re: @#$%&*!]
#570902
01/03/10 03:58 PM
01/03/10 03:58 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
This is the best plan , I wouldn't cut the bleep out of the heads for a bandaid and then once you redo the shortblock you run into a new problem ... TOO MUCH compression because you you halfassed it the first time ...
[Re: JohnRR]
#570903
01/03/10 04:22 PM
01/03/10 04:22 PM
RapidRobert
What they said, I would not cut/mill anything instead I'd either bolt it together w an .020" or thicker if need be gasket or I'm wondering if it would it be possible/practical to pull the pan/rods/pistons & R&R the pistons with some higher CR ones and balance them to the orig piston/pin/rings weight and ball hone the block plus that'd give you fresh rings but as I am typing I realized that the KB's MIGHT be much different in weight than the oe's but not sure if the diff would be enough to badly screw up your bobweight. I'm a firm believer in running what you have in the car now & maximizing it as opposed to what might come about in the future but the CR in the low 8's or even likely in the low 7's is really going to be a problem (change the cam to build some psi).
[Re: RapidRobert]
#570906
01/03/10 05:26 PM
01/03/10 05:26 PM
DaytonaTurbo
Manitoba, Canada
He's probably got enough of a ridge in his cylinders that they'd be rough on rings with a higher CR piston.
I agree, milling heads is more trouble that it's worth. Save the money towards your engine rebuild later on down the road.
Also your stock heads were more like 90cc with a .020 gasket. The source heads have been cc'd by others to be more like 86cc. 86cc with a .039 gasket will give you the same CR as stock 90cc with ah .020 gasket. No loss, no gain there. I've got a 76 440 with stock smogger pistons, I put in a new set of rings, bolted on a set of 440source heads, headers, lunati voodoo 60303 cam and (temporarily) a stock intake and thermoquad. It runs well and puts out good torq considering I threw it together out of parts I had laying around.
[Re: timinator]
#570907
01/03/10 10:21 PM
01/03/10 10:21 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I just redid my Jensen's engine, it was a rebuilt 440 .030 when I bought it, I took a peek and noticed the cam was .250 lift, .375 at the valves. New cam, but puny in a crazy way. I pulled the heads, the pistons were aftermarket, I milled my heads .030" and used a Felpro gasket, which didn't raise my compression much, but it didn't LOWER the commpression with thicker gaskets either.... I went with a 270H Comp Cam, I have 9.35 to 1 measured compression, and I did a bit of headwork while I had it apart. It idles strong and smooth (ish), has good free response, but I won't know what it goes like until spring when I get it on the road..... It's a factory 1974 440 HP engine with a steel crank. Weird? I've cut iron stock heads .030" and used Felpro gaskets for years, the intake bolts up, compression doesn't get worse, but milling nowadays costs a lot more than milling used to- I paid $100 a head when I used to pay $40 a pair...
CrAzYMoPaRGuY
