challenger fuel gauge off after installing new sending
#569140
01/01/10 10:48 PM
01/01/10 10:48 PM
Posts: 233 vashon island washington
hunterstroble
I have a 73 challenger. I installed a 3/8" sending unit/pickup and now when my gauge should read half it's close to empty. I figure if I had to I could reattactch my old sending unit. But honestly don't feel like getting covered in gas. Any tricks, can the gauge needle be pulled off and repositioned? Thanks very much everyone!
1969 Dodge dart 500 stroker
1973 Dodge Challenger 440
Re: challenger fuel gauge off after installing new sending
[Re: 1_WILD_RT]
#569142
01/01/10 11:05 PM
01/01/10 11:05 PM
hunterstroble
it's one I don't even remember where I bought it from, so i can't return it. Probobaly best to order a new one.
[Re: AARCONV]
#569144
01/01/10 11:26 PM
01/01/10 11:26 PM
Posts: 15,491 the boonies
aarcuda
the boonies
bad ground on the sending unit???
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: aarcuda]
#569145
01/01/10 11:36 PM
01/01/10 11:36 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Most of the new aftermarket ones are off some.Most need some adjusting also.I have a SS 3/8 one in my 65.Its off probally less than 1/8 of a tank.I did have to tweek the arm a bit on mine.Even from the factory some were not very accurate.Rocky
Chrysler Firepower
[Re: Snoopy]
#569147
01/02/10 12:05 AM
01/02/10 12:05 AM
hunterstroble
the unit body is grounded. And i know has 1/2 tank of gas in it. Old sending unit read 33 ohms near half, new unit in tank reads 33 ohms, but gauge is just above e. spikes to full when i ground the wire. The gauge worked fine before i replaced it, guess i have to pull the new one out and run ut through the scale. I just thought 33 ohms would show alot more than just above e.
[Re: CokeBottleKid]
#569149
01/02/10 11:24 AM
01/02/10 11:24 AM
Challenger 1
Cincinnati, Ohio
Sounds like your sending unit ground is bad...
Check that first.
The proper way to check it is what Snoopy posted. Good post.
Check it with a known good ohm meter before putting it into the tank. If you can't get those readings by bending the float arm or stop, then return it and get another sending unit.
The gauge in the dash has never been off on the cars I've worked on.
[Re: Challenger 1]
#569150
01/02/10 01:29 PM
01/02/10 01:29 PM
hunterstroble
My car is not at my house so i'll check it again in a couple days. I'll try running a better ground to my sending unit body, then pull it out if that doesn't work. It's just weird, 33 ohms should be nearly half on my gauge, sure acts like a bad ground though. maybe i'll run a temporary jumper ground to my battery - terminal in the trunk.
[Re: stumpy]
#569152
01/02/10 07:29 PM
01/02/10 07:29 PM
hunterstroble
it could be bent, i never looked. I just installed it into the new tank and put the whole assembley into the car. I pull it out next weekend and check.
[Re: hunterstroble]
#569153
01/02/10 08:33 PM
01/02/10 08:33 PM
hunterstroble
The arm was bent and my ohms were all glittchy and all over the map. installed all the sending unit guts from my old pickup onto the new one and wha-la! Thanks for everyone's help.
