Re: Stainless polish
[Re: GTXKen]
#566712
12/30/09 11:06 AM
12/30/09 11:06 AM
Posts: 196 out front
jerrya
Comin to a Labor Day Telethon
out front
I use WENOL. Bought it on ebay.
Man does not plan to fail... he fails to plan
[Re: dodgy]
#566714
12/30/09 04:15 PM
12/30/09 04:15 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
I like using Mothers polish--after I wet sand the trim with super fine wet sandpaper (600,1000,1500,2000 grit) depending on condition. On smaller pieces,I use a buffing wheel on a dremel tool.I also have a vintage Dremel shoe polisher that buffs stainless out nicely. But mostly I work it by hand.I apply it with my bare fingers,sometimes use a toothbrush and buff with a cloth diaper before it hardens up. Lots of work with great results.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: screamindriver]
#566716
12/31/09 07:23 PM
12/31/09 07:23 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Not meaning to change the subject,,but what will take the clear anodizing off aluminum so you can buff it??? I read something awhile back, but don't remember what they said to use. I'm thinking oven cleaner or something similar,,but that doesn't seem to work.
If you like drag racing, support your local track.
[Re: CHAPPER]
#566717
12/31/09 07:40 PM
12/31/09 07:40 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Oven Cleaner. Now back to the subject of stainless. 400 grit until all the scratches and pits are out. Then 600 and wet sand beyond that. Final polish with a Dremel or drill with a buffing wheel and jewelers rouge using very little pressure or you will put in swirl marks and have to start over again. Best is to practice on a scrap piece. For me, it is relaxation therapy. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: elitecustombody]
#566720
12/31/09 09:47 PM
12/31/09 09:47 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
if you have acess to a buffing wheel,brown tri-poli on sewn buffing wheel will make it look like new,you can pick wheel,polish stick and even buffer at your local Harbor Freight store. I can post some pics of my polish work with mentionned items
Thanks everyone for the suggestions. Yes I would like to see some of your work. Please post away.
[Re: bigblock340power]
#566721
01/01/10 01:28 AM
01/01/10 01:28 AM
Easy-Off oven cleaner.
It may take a couple of applications but the lye in it WILL take off anodizing.
Don't cheap out and get an off brand and don't by the fume free junk.
It took 3-4 applications on a warm day to get all the anodizing off my '63 Dodge grille.
