440 compression ratio question #560427
12/23/09 01:59 AM
12/23/09 01:59 AM
Indiana
O
Osyman Offline OP
Osyman  Offline OP
O
Indiana
does anybody know the c/r of the 75 440 police interceptor? I ordered .030 over pistons with the same c/r that was in the interceptor, then put the '67 closed chamber heads on it. do yall know my new c/r?
also anyone know the specs of a stock 426 hemi cam?
Re: 440 compression ratio question [Re: Osyman] #560428
12/23/09 02:03 AM
12/23/09 02:03 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
To get an acurate number you would need to measure how far the piston is in the hole @ TDC & CC the heads... Without that info I'd guess roughly 8.5-9.0 to 1..
Re: 440 compression ratio question [Re: 1_WILD_RT] #560429
12/23/09 02:06 AM
12/23/09 02:06 AM
Indiana
O
Osyman Offline OP
Osyman  Offline OP
O
Indiana
i believe the heads are 72 or 75cc, ill check the piston depth. thanks
Re: 440 compression ratio question [Re: Osyman] #560430
12/23/09 02:15 AM
12/23/09 02:15 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
with a standard deck they typically cc around 78-80 cc's.
Aftermarket pistons, it's anyones guess as to the ratio.
Plug the measurements into a comp ratio calculator, like the one at www.kb-silvolite.com
The numbers are usually surprising, and not in a good way.
Re: 440 compression ratio question [Re: dave571] #560431
12/23/09 02:59 AM
12/23/09 02:59 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
75 police 440 was just a 440HP which featured a whopping 7.8:1 (calculated) compression from the factory with stock 452 heads. With your smaller closed chambered heads that's more like 8.4:1 compression, assuming those are stock replacement mid 70's 440 pistons and assuming you didn't mill your block or heads to increase cr. If those are truly the pistons you bought, those are basically the least desirable 440 piston out there.
Re: 440 compression ratio question [Re: Osyman] #560432
12/23/09 09:09 AM
12/23/09 09:09 AM
pa
73roadbird Offline
73roadbird  Offline
pa
I don't know if this will help you or not, but I'm working on a 75 440 that's out of a truck, and the pistons measured .0160 to .0162 down, so compression would be quite low from factory. Not to hijack this post, but could I deck the block and re-use the factory pistons or get earlier year 440 pistons to get a better compression ratio. Looking to do a budget build, Thanks...
Re: 440 compression ratio question [Re: 73roadbird] #560433
12/23/09 10:27 AM
12/23/09 10:27 AM
You're too far in the hole. I'd get some KB's to get .040" Quench and a higher CR and you'll be MUCH more satisfied w the outcome.
Re: 440 compression ratio question [Re: 73roadbird] #560434
12/23/09 10:28 AM
12/23/09 10:28 AM
i think you meant .160 & .162 down in the hole. .0160 & .0162 actually isn't that bad. would give you around 9.2:1 CR. with open chambers.
Re: 440 compression ratio question [Re: RapidRobert] #560435
12/23/09 12:41 PM
12/23/09 12:41 PM
Manitoba, Canada
Manitoba, Canada
If you're on a budget and want compression, do yourself a favor and buy the KB237's or even the TRW2355's.
Re: 440 compression ratio question [Re: Osyman] #560436
12/23/09 02:23 PM
12/23/09 02:23 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
You should stop the order for those replacement pistons, I agree that you will have less than 8.5-1 compression with those pistons and 915 heads. I would order some TRW 2355 pistons at the very least, that will get you between 9 or 9.5-1 compression.
Sheldon
Re: 440 compression ratio question [Re: RUNCHARGER] #560437
12/27/09 06:46 PM
12/27/09 06:46 PM
Stow,Ohio
RBSat66 Offline
RBSat66  Offline
Stow,Ohio
If interested I am taking a set of TRW 2355 + .030 pistons with stock rods out of a 440.
Re: 440 compression ratio question [Re: 73roadbird] #560438
12/28/09 12:46 AM
12/28/09 12:46 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
You can buy new KB hyper pistons from summit for 310 bucks with a .075 quench dome or 320 for flat tops (I have no idea why the flat tops are 10 bucks more).
Re: 440 compression ratio question [Re: dodgeboy11] #560439
12/28/09 12:48 AM
12/28/09 12:48 AM
Manitoba, Canada
Manitoba, Canada
Yes the only downside being you have to have your rotating assy rebalanced. With the TRW's they're made so their weight is 'close enough' to stock pistons that many guys run without a rebalance.
