Truck 440 build recipe
#558565
12/20/09 04:00 PM
12/20/09 04:00 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Trying to do my first 440 buildup. This will also be the first engine I've ever put together my own shopping list for and I could use a little help to make sure I'm not wasting money with mismatched parts. With that said, the engine is going in an 80 ramcharger with a 727 and 4.11 gears. I'm trying to stick to a budget and reusing parts. Ill be using the factory 452 heads that were on it and the edelbrock performer intake. I've got the tools and skill to port the iron heads with the molar templates. The block is already .030 over and there is rust on he back cylinders so it will have to go at least, at a minimum .040. I guess the two variables to my build are pistons and cam. I've considered the summit 6401 kit for the cam. I know the pistons in there right now are .155" in the hole, calculating out to 7.7:1 CR. What should I shoot for for pistons. An actual part number would be appreciated. I would like stump pulling torque and some nice stop light-to-stop light power, while running on pump has with good reliability. Lets hear your tried and true recipes and/or opinions on my build. Thanks
Re: Truck 440 build recipe
[Re: SomeCarGuy]
#558567
12/20/09 04:57 PM
12/20/09 04:57 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
What about a stock oem replacement cast piston for the 68-71 440 hp motor? Seems like a set made by Silvolite or Badger would not be expensive and be closer to the deck at TDC. Does badger even exist anymore?
Keep old mopars alive.
[Re: Pat_Whalen]
#558572
12/20/09 10:54 PM
12/20/09 10:54 PM
RapidRobert
might spend the extra to get .040" quench so you can run a higher CR on the same octane gas. It will take some extra as you'll have to machine each open head recess to equalize them as the slope and depth varies but you want all the torque you can get and as said you dont want to end up w a dog after all this work.
[Re: Pat_Whalen]
#558573
12/20/09 11:41 PM
12/20/09 11:41 PM
DaytonaTurbo
Manitoba, Canada
KB237 pistons for sure. You won't have quench, but without milling the block at all and with the .020" steel shim head gaskets you should be at around 9.5 compression. With the right cam and premium fuel it will do okay. Actually I would deck the block to bring the pistons to zero deck while you're in there, that way if you ever choose to go to aftermarket closed chamber aluminum heads in the future, you'll be setup perfect for them. You can run the big summit cam if you're needing to pinch an extra 80 bucks from the budget. I would be more likely to look at the comp xe275hl or lunati voodoo 60304 myself. But both of the above suggestions are assuming you're going for more of a street machine than a tow/utility/4x4 rig.
[Re: DaytonaTurbo]
#558574
12/21/09 02:33 AM
12/21/09 02:33 AM
Pat_Whalen
super gas
super gas
Mesa, AZ
The truck in question will actually be a daily driver (economy is marginally important, all things being considered), and will see frequent off road and trail use.
I just poked around the COMP website and was pretty enamored by the tech they've got on cam selections. Now I've got my eye on the xe256h (256*/268*, .447"/.455"). Or should I step up to something like the xe262h (262*/270*, .462"/.470")?
Thanks for all the help thus far.
[Re: Pat_Whalen]
#558575
12/21/09 02:52 AM
12/21/09 02:52 AM
Posts: 30,430 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
I would SERIOUSLY consider putting in a 413 from a motorhome. They are fairly cheap and have that stump-pulling-torque.
[Re: DaytonaTurbo]
#558577
12/21/09 08:02 AM
12/21/09 08:02 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I'm running the 275 in my "440" (383, .060 over, 3.750 stroke--438 cu in) with flat top Ross pistons, .040 head gasket, eddy closed chamber heads and that XE-275-HL cam, when I had the power brakes on the truck, it had more than enough vacuum to keep them happy, and it makes gobs of torque, attached is a graph from my dyno visit. peak torque was 535, but was over 500 ft lbs from 3,000 rpm through 5000 rpm. with a properly matched torque converter and 4.10 gears, that cam would do well in a "stock 440" (with OEM heads)
it's got a really nice lope to it as well at idle. I run pump gas through it and never had a problem, and I've had both OEM iron heads and the eddy aluminum heads on this engine with that cam.
**Photobucket sucks**
[Re: scratchnfotraction]
#558579
12/21/09 10:10 AM
12/21/09 10:10 AM
Pat_Whalen
super gas
super gas
Mesa, AZ
hey Pat
did you get the Motor mounts and xmember worked out?
on to the rebuild
I had actually written the big block off at the moment in favor of a fully assembled small block, just to get the truck running for the coming summer with plans to build the 440 in the meantime. Unfortunately, tearing down the smallblock just to check it revealed some really disastrous rust that would have required even more dough to rebuild than the big block. So the 440 got the nod, and I'll have to still straighten out the engine mount situation. I have decided to save myself some time and aggravation though by finding a suitable mated 727/np208 as opposed to trying to custom fit the 2wd 727 and divorced np205. I'd still like the 205 for the power the big block will be putting out, but I'll have to live with a 208 for the time being.
[Re: Pat_Whalen]
#558581
12/23/09 09:02 AM
12/23/09 09:02 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
for a heavy truck with an emphasis on daily driver duty, I'd probably use the KB237's, setting them up near 0 deck, and for a cam, I'd look at a comp XE268 or a lunati voodoo 60303, using comp 915 springs with either.
