Dynamat Question #558454
12/20/09 01:03 PM
12/20/09 01:03 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Anybody run this? Just wondering if you have any problem with condinsation between the mat and floor pans. Thanks
Re: Dynamat Question [Re: bobs69] #558455
12/20/09 02:29 PM
12/20/09 02:29 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I would not worry if the floor is prepped properly with primer and paint.
Re: Dynamat Question [Re: bobs69] #558456
12/20/09 06:01 PM
12/20/09 06:01 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Dynamat goes down as tight as you want to work it. It is rubberized and becomes completely adhered to the metal. If the pan is solid there is no problem.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
