Winter hibernation part # 2 Valve springs. #556718
12/18/09 01:36 AM
12/18/09 01:36 AM
fullmetaljacket Offline OP
Since my car is getting a new trunk floor this Winter season and the fuel tank is out of the car meaning that the engine will not be starting any time soon, should I go under the valve covers and back off the rockers to relieve the pressure on the springs to save their strength?
Re: Winter hibernation part # 2 Valve springs. [Re: fullmetaljacket] #556719
12/18/09 01:51 AM
12/18/09 01:51 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
yes, you should do it every off season.
Re: Winter hibernation part # 2 Valve springs. [Re: TS3303] #556720
12/18/09 02:04 AM
12/18/09 02:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
...no reason to have load on the spring for
the off season.... unless you start it every few weeks
Post deleted by Defbob [Re: MR_P_BODY] #556721
12/18/09 02:12 AM
12/18/09 02:12 AM
Re: Winter hibernation part # 2 Valve springs. #556722
12/18/09 02:14 AM
12/18/09 02:14 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
if you can just rotate the motor often like once a week you'll see no spring loss. a few years backI did mine only once a month and loss nothing
the extra benefit is all the valves will be closed sealing up the engine. you never know what may wander in from the hog pen.
Re: Winter hibernation part # 2 Valve springs. [Re: TS3303] #556723
12/18/09 02:20 AM
12/18/09 02:20 AM
I gather spraying some oil in each cylinder through the spark plug holes would be beneficial also right?
Post deleted by Defbob [Re: TS3303] #556724
12/18/09 02:30 AM
12/18/09 02:30 AM
Re: Winter hibernation part # 2 Valve springs. #556725
12/18/09 02:38 AM
12/18/09 02:38 AM
Arizona
Chris'sBarracuda Offline
Arizona
for cylkinder walls I was going to use the treatment my buddy does at his marina. pours stuff down the carbs when running and shuts then it off
Hey Fred.. Would that be Jack Daniels or George Dickel??
Chris..
Re: Winter hibernation part # 2 Valve springs. [Re: Chris'sBarracuda] #556726
12/18/09 03:43 AM
12/18/09 03:43 AM
Freeport, Pa
W
whiskeyrunner Offline
W
Freeport, Pa
trans fluid
