68 GTX anti-sway bar Question #556367
12/17/09 06:22 PM
12/17/09 06:22 PM
East KY
N
nbbcrh Offline OP
nbbcrh  Offline OP
N
East KY
Quick Question-
I have a 68 GTX Front anti-sway bar and the lower control arms. My question is Will this anti-sway bar work on a 67 B-body with the matching lower control arms with tabs or are they too wide for the 67-body. Thanks Ben
Need your help on this, I'm thinking it would be the same since all 66-70 b-body's use the same inner fenders and radiator support but need somebody that would know for sure before I switch out the lower control arms.
Re: 68 GTX anti-sway bar Question [Re: nbbcrh] #556368
12/17/09 09:38 PM
12/17/09 09:38 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Yes there the same. The only difference is the taps for sway bar bracket. They will bolt right up.
Re: 68 GTX anti-sway bar Question [Re: Dougsmopars] #556369
12/18/09 08:15 PM
12/18/09 08:15 PM
East KY
N
nbbcrh Offline OP
nbbcrh  Offline OP
N
East KY
Thanks Doug, I appreciate your help.
