Parking Brake Bracket #554061
12/14/09 09:38 PM
12/14/09 09:38 PM
Cheswick, Pennsylvania U.S.A.
JRod01 Offline OP
JRod01  Offline OP
When you install a spring relocation kit you have to remove your parking brake cable brackets. I want to reinstall them but where is the best location? Do I have to modify the cable/housing itself somehow? Any and all help is always appreciated, thanks!
-73 Duster
"Oh man there is nothing finer than being behind the wheel of your own automobile." -Christine
Re: Parking Brake Bracket [Re: JRod01] #554062
12/14/09 10:06 PM
12/14/09 10:06 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
i just drilled out the spot welds, and welded them right to the same spot they were in, just now they are on the side of the spring box. I didnt modify the cable at all.
....BAD A$$ STREET CAR.....
Re: Parking Brake Bracket [Re: n20mstr] #554063
12/14/09 10:11 PM
12/14/09 10:11 PM
JRod01 Offline OP
JRod01  Offline OP
Thank you, that's what I had in mind but wasn't sure if cable length changed or if there was any kind of interference. Sounds good!
