dana 60 spool ? #553767
12/14/09 03:36 PM
12/14/09 03:36 PM
Ky
moparmafia Offline OP
Ky
how can i tell the difference between spools that are for low gears or higher gears? also what are the different series spools that i see from different suppliers? who has the best deal on gears, spools and axles? anyone on the board sell them or have a package deal? thanks
Re: dana 60 spool ? [Re: moparmafia] #553768
12/14/09 04:08 PM
12/14/09 04:08 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Contact Cass (Dr Diff)
He will set you up, and has great customer service, and prices.
The diff series spools, accommodate diff gear ratio's. Usually 4.56 4.88 and numerically higher gears require a diff series of spools than like 4.10 gear sets. This is due to the thickness of the ring gear, which requires the ring gear to be spaced accordingly to the pinion.
Re: dana 60 spool ? [Re: moparmafia] #553769
12/14/09 04:23 PM
12/14/09 04:23 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Distance from bearing stop to gear mount surface would be one way.
Which are you looking for. I know where a 35 spline 3.54-4.10 Strange pro spool is...
