505 headed back to the dyno
#55270
03/22/08 12:55 AM
03/22/08 12:55 AM
Posts: 31,023 Oregon
AndyF
She looks nice, we'll see what kind of power it makes. With the new Jesel valvetrain the cam lift is around 0.800. Other changes are the belt drive, belt driven distributor, crank trigger, 440-3X intake, and the reverse flow water pump.
EDIT - the motor made 674 ft-lbs at 6100 rpm and 805 hp at 6400 rpm.
Re: 505 headed back to the dyno
[Re: AndyF]
#55271
03/22/08 02:15 AM
03/22/08 02:15 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Cool stuff as always Andy.
Is that an oberg oil filter?
Whats the benefit of the belt driven distributor?
Doc.
[Re: AndyF]
#55274
03/22/08 12:16 PM
03/22/08 12:16 PM
NTOLERANCE
Madison Wi
Sure looks like an olberg filter I used to have, only it wasnt gold.
I assume the dist. is run off the cam?
[Re: AndyF]
#55278
03/22/08 02:41 PM
03/22/08 02:41 PM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
I also provided the info to Russ at Indy but he didn't seem to impressed. Maybe I just caught him in a grumpy mood or something. Imagine That !!!! Is this engine for competition or something? ...I have not been paying attention
[Re: AndyF]
#55279
03/22/08 03:09 PM
03/22/08 03:09 PM
Posts: 5,875 communist bloc of new jersey
jamesc
yea heaven forbid you should improve something...once again you've lost your mind Andy. i went through some agg with ARP studs for a megablock. when i called ARP they said that the standard hemi kit would work for this application but when the guy gave me the lengths they weren't the lengths i believed would work when i measured things up. ordered the hemi kit and they were too short ended up sending them back and ordering loose studs in the lengths i measured which fit correct. told ARP they should look into packaging these lengths for a megablock kit. don't know if they ever did but i don't think so
[Re: AndyF]
#55280
03/22/08 03:49 PM
03/22/08 03:49 PM
We used the standard offset exhaust rocker arms on both the intake and the exhaust and had some custom spacers made up to center the intakes on the valves.
that's a very nice looking setup. the above statement seems alittle confusing to me though. it doesn't look like all those rockers are exhaust rockers???
what are you using to hold the intermesiate shaft in place since there's no dist. in the hole?
what dimension did you come up with for the milling of the head to accept the jesel stands. it's not like i'd probably ever do all that but it'd be great info just the same.
[Re: AndyF]
#55282
03/22/08 04:11 PM
03/22/08 04:11 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Looks great, Andy. Did you change cams or are you still running the solid flat tappet? Looking forward to hearing the results. BTW, that Indy 3X sure looks big .
2 kids and a dog
[Re: MR_P_BODY]
#55284
03/22/08 05:40 PM
03/22/08 05:40 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Andy, your new wires for the front-mount are being built next week, and you will have them by next week for real-world dyno tests. Thanks for waiting for the 8.5 mm's. Awesome work , bud. You have a fun job !!!!
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: AndyF]
#55287
03/22/08 07:57 PM
03/22/08 07:57 PM
very good info, thanks. what installed height and diameter on the springs did you end up with?
[Re: AndyF]
#55288
03/22/08 08:06 PM
03/22/08 08:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Here is a picture that shows the difference between using exhaust rocker arms on the intake and using the 440-1 offset intake rocker arms.
The cylinder on the left has the 440-1 intake rocker arm which moves the pushrod over too much for the EZ head. The cylinder on the right has two exhaust rocker arms and the pushrod lines up in the proper location.
Andy, in the last pic here is the tip roller parallel with the pivot shaft(the large shaft) or is it parallel with the C/L of the rocker, I cant really see, looks like its a optical elution
