factory tach??
#552450
12/13/09 09:28 AM
12/13/09 09:28 AM
Posts: 316 Coolville, Ohio
Lew
Coolville, Ohio
E body tach on a freinds car reads to high, any suggestions on this, thanks.
Re: factory tack??
[Re: Lew]
#552451
12/13/09 09:37 AM
12/13/09 09:37 AM
E body tack on a freinds car reads to high, any suggestions on this, thanks.
did he put a msd box in it? if so you'll need a tach adapter from msd.
Re: factory tack??
#552452
12/13/09 09:41 AM
12/13/09 09:41 AM
also sometimes when you add the tach adapter the tach will read a little higher, its not liking the old eectronics in the factory tach, you'll need to send it out and get modern electronics put in it to get it to work properly.
Re: factory tack??
#552453
12/14/09 04:33 PM
12/14/09 04:33 PM
Lew
Coolville, Ohio
no msd factory points.
Re: factory tach,??
[Re: Sssnake383]
#552455
12/14/09 06:05 PM
12/14/09 06:05 PM
Lew
Coolville, Ohio
Could need to be calibrated. How high does it read? I once had a tach read double the actual RPMs. I lived with it until one day the car wouldn't start. The resto coil was the culprit. A new coil and the car started...BUT - it also solved my tach problem. Must have been an internal short or break in the coil, I don't know. But the tach reads correctly now with the new coil, FWIW.
Thanks for that piece of info, he or i should have a good coil to try, see what happens.
