Square sticky pads on floor pans under seat belt bolts? #552200
12/12/09 07:23 PM
12/12/09 07:23 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hi, what is the purpose of these pads? What are they made of? Are they available? Any info is appreciated.
Re: Square sticky pads on floor pans under seat belt bolts? [Re: cudabitten] #552201
12/12/09 11:51 PM
12/12/09 11:51 PM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
I think I had the same thing on my car. Its a 69 RRunner and it had what looked like stainless or aluminum squares stuck over the seat belt holes. It was kinda odd cause it looked like they had been there awhile. I have no reason why they were there, but hope maybe someone might have an explanation.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: Square sticky pads on floor pans under seat belt bolts? [Re: cudabitten] #552202
12/13/09 01:16 AM
12/13/09 01:16 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
What year and model.
Re: Square sticky pads on floor pans under seat belt bo [Re: cudabitten] #552203
12/13/09 02:48 PM
12/13/09 02:48 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
Like these? I think they were seals on the seatbelt bolts that went through the floorboards. These are from my 74 Road Runner.
It is a rubbery material and there are voids (air bubbles) in the face that was against the floorboard. I doubt it was something applied wet on the floorboards - more likely they were made on some other substrate then peeled off and applied to the floorboards before the bolts went in.
Upon further consideration the color on the topside is gold overspray from when the car was painted. These were definitely in place well before the bolts went into the holes. Could have been applied wet to the floorboards, although that would be awful time consuming on an assembly line.
Re: Square sticky pads on floor pans under seat belt bo [Re: Runnin74] #552204
12/13/09 03:16 PM
12/13/09 03:16 PM
Snoopy Offline
Snoopy  Offline
I wonder if someone on the line failed to remove the paint plug before installing the seat belts?
Re: Square sticky pads on floor pans under seat belt bo [Re: Snoopy] #552205
12/13/09 03:21 PM
12/13/09 03:21 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
I'll bet that's it! Thanks Snoopy.
Re: Square sticky pads on floor pans under seat belt bo [Re: Snoopy] #552206
12/13/09 03:44 PM
12/13/09 03:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Ding Ding Ding Winner Winner Chicken Dinner...
Re: Square sticky pads on floor pans under seat belt bo [Re: 1_WILD_RT] #552207
12/13/09 05:17 PM
12/13/09 05:17 PM
eastern, pa.
eastern, pa.
Thanks,
If thats true then I will remove these before I re-finish my floors. I was thinking they were a gasket to seal out water? Found some missed welds too, so this does not surprize me.
Re: Square sticky pads on floor pans under seat belt bo [Re: cudabitten] #552208
12/13/09 05:22 PM
12/13/09 05:22 PM
Snoopy Offline
Snoopy  Offline
I looked through all my parts books and the few assembly drawings I have and was unable to find any reference to anything between the seatbelt anchor and the floor.
It wasn't until Runnin74 posted his pictures that I connected them with instruction number 1 on one of the assembly prints.
Sometimes pictures are worth a thousand words.
Re: Square sticky pads on floor pans under seat belt bo [Re: Snoopy] #552209
12/13/09 06:17 PM
12/13/09 06:17 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Snoopy, what year is your assembly print from. Is is possible that in earlier years, they were supposed to remove the plug...but then discovered later that it was a waist of time and just left them on? I found some reddish/brown RTV like stuff under the seat belt bolts on my 73 Challenger. It looks to be the same thing as was pictured.
Re: Square sticky pads on floor pans under seat belt bo [Re: burdar] #552210
12/13/09 06:26 PM
12/13/09 06:26 PM
Land of 10,000 Lakes
44D6PAKCUDA Online content
44D6PAKCUDA  Online Content
My '70 Duster still has them on the floor pan on every seat belt hole.
Re: Square sticky pads on floor pans under seat belt bo [Re: burdar] #552211
12/13/09 07:50 PM
12/13/09 07:50 PM
Snoopy Offline
Snoopy  Offline
Feb 3, 1970. My guess is that it wasn't a make or break thing for inspection. The only down side would be the loosing of the bolt do to the compressibility of the soft plug. Because the bolt goes into a weld-nut, the pad would serve no purpose . If sealing was a problem, they could have used a sealant on the bolt threads or used an encapsulated nut.
Re: Square sticky pads on floor pans under seat belt bo [Re: Snoopy] #552212
12/13/09 10:10 PM
12/13/09 10:10 PM
WI
RestoRick Offline
RestoRick  Offline
WI
I believe these are sealing squares used over the seat belt bolt holes, much like the smear of tar often found.
I think the plugs used in the seat belt bolt holes referred to in Snoopy's document are the black rubber plugs seen in the picture below.
I've found them under carpeting numerous times.
Rick
Re: Square sticky pads on floor pans under seat belt bo [Re: cudabitten] #552213
12/13/09 11:01 PM
12/13/09 11:01 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Thanks,
I've had lots of cars with these square seals, cant remember which cars but have seen it alot.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Square sticky pads on floor pans under seat belt bo [Re: mopargem] #552214
12/14/09 12:47 AM
12/14/09 12:47 AM
Snoopy Offline
Snoopy  Offline
Rick,
How do explain the paint on the pads?
Maybe the pads where used after the drawing I posted? Assuming that the plugs referenced were like the ones you show in your picture, the pads may have been an engineering solution to disposal problem with the black rubber plugs. It would make since to replace a pain in the butt part that required removal and disposal with a part that could be left in place. This would explain why cars like mine did not have the pad and there was no sign that it had been there and then removed after paint.
Maybe someone with a later drawing can shed some light on the subject.
Re: Square sticky pads on floor pans under seat belt bo [Re: Snoopy] #552215
12/14/09 12:58 AM
12/14/09 12:58 AM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
I have always seen those in my cars i removed carpet on. Thought they were a seal of some sort.
74 Duster
73 Dart Sport
74 Dart Sport
74 Challenger
73 Duster
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Square sticky pads on floor pans under seat belt bo [Re: Snoopy] #552216
12/14/09 01:18 AM
12/14/09 01:18 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Rick,
I'm speculating too...
Paint on them would be a matter of when they were stuck on... the tar sealer they used was smeared on after dip gray, but before topcoat painting.
Yes, I could see where it could've been a two-part solution... seal the threads from paint & later poke the bolt through with no rubber plugs laying around.
I can imagine those plugs ending up on the floor could've been a real tripping-slipping hazard!
Re: Square sticky pads on floor pans under seat belt bo [Re: RestoRick] #552217
12/14/09 02:50 AM
12/14/09 02:50 AM
Snoopy Offline
Snoopy  Offline
Me too.
I am afraid that without a source to every factory print, engineering change notice, memo, TSB and anything else Chrysler used to convey production line changes. Sometimes we are reduced to educated guesses. I am glad that we have people like you, Joe, Barry, Terry, Jules, Dave Walden, Bill and all the other people that take the time to document unmolested cars and are willing to share their knowledge with fellow enthusiasts.
Re: Square sticky pads on floor pans under seat belt bo [Re: Snoopy] #552218
12/16/09 02:04 PM
12/16/09 02:04 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
my theory is the pads were protection to the floor from the seat belt mounts and a seal to keep out moisture from gathering in the recessed area which could weaken the seat belt attachment area.
this is MY theory
Re: Square sticky pads on floor pans under seat belt bo [Re: RestoRick] #552219
12/16/09 10:38 PM
12/16/09 10:38 PM
cataclysm80 Offline
cataclysm80  Offline
Tav
