Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS!
#539
06/03/03 10:39 AM
06/03/03 10:39 AM
Posts: 869 Sugarloaf, PA. USA
JamiePasson
Sugarloaf, PA. USA
Main case weighs just 14 lbs. vs. 36 lbs. in cast iron. A Body tail weighs 6 lbs. vs. 18 lbs. in cast iron. '66-'69 B Body tail weighs 8 lbs. vs. 21 lbs. in cast iron. '70 - '74 B / E Body tail weighs 8 lbs. vs. 21 lbs. in cast iron. Sidecover weighs 2 lbs. vs. 5 lbs. in cast iron. It has extra ribbing inside. Main case countershaft bore is already bushed. Sidecover bores are bushed as well.
[Re: JamiePasson]
#548
06/03/03 12:15 PM
06/03/03 12:15 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
jamie , looks good .
a few questions , is that B body shift mount a machined piece like the e body or is that a stocker cast piece you happen to have ?
had you put any thought or effort into replacing the roller bearings the factory used with a taper roller bearing ? i can see one stumbling block , but i haven't made the measuremments yet to see if parts from a T5 can be retro fitted between the mainshaft and the iput shaft .
also , have you assembled on and had it installed behind a high HP engine in a racing atmosphere ?
my need is for stock appearing racing and if it can handle a wide open throttle shift with a 550 plus HP engine its of little good to me ...
unfortunately the stock appearing guys as well as resto anal freaks will have to grind off your logos ...
[Re: JamiePasson]
#549
06/03/03 12:25 PM
06/03/03 12:25 PM
Posts: 995 VA
Ed_Devinney
super gas
super gas
VA
Ed, Main case ready to go. $250.00 Tailhousing, ready to go $250.00 Sidecover $75.00
Buy the whole set $550.00
Not bad, folks - it's cheaper than steak on a per-pound basis :-)
I already have an aluminum tail housing and have to pull the trans to fix the tailshaft busing. Have to check how much work to rebuild the trans and go from there...
[Re: Ed_Devinney]
#550
06/03/03 12:35 PM
06/03/03 12:35 PM
COOL. Jamie, do you have a price list or catalog i could look at for ideas? and is it online? ![](/ubbthreads/images/graemlins/grin.gif) How much power can these take?and whats the threshhold gain over stock?
nice looking peice!!!
[Re: JamiePasson]
#554
06/03/03 01:28 PM
06/03/03 01:28 PM
This ought to shed a few pounds on those F.A.S.T. cars!
#555
06/03/03 01:41 PM
06/03/03 01:41 PM
Posts: 111 Uppsala, Sweden
Satanized_68
Uppsala, Sweden
That makes me really wanna go back to 4-speeds!
Shed some weight, retain the strength.
Great work!
Getting closer... <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
