Re: Leaf Spring Clamps - Anyone Use Them?
[Re: '72CudaRacer]
#551056
12/11/09 01:18 PM
12/11/09 01:18 PM
Posts: 7,861 Witness Protection Program
Kudakidd
I made my own. 1/4" flat bar,1 1/2" wide and a couple of bolts. Just make sure not to place them near the tires.
Notice any difference in your launch or 60' times?
[Re: '72CudaRacer]
#551060
12/11/09 03:40 PM
12/11/09 03:40 PM
Kudakidd
Its mostly trial and error. But its easy and cheap. I had to keep a clamp on the rear because after the springs seperated and then came back together, the leafs would sandwich the rear valance. I finally cut a couple of inchs off the ends of some leafs to stop that. And yes, it does help 60'. Brian
Totally cool race car you have there, Brian! Thanks for the tips.
[Re: Crizila]
#551062
12/11/09 04:08 PM
12/11/09 04:08 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
They do help the 60' times.
The snubber is a bit different, if it's too close the car can develop some handling issues, as it can act like a fulcrum and the car can pivot on it.
I like the idea of using one as a safety issue, but a lot of guys don't like them at all.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: Kudakidd]
#551065
12/12/09 12:51 AM
12/12/09 12:51 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
I used them on my M.W. stocker way back before super stock or replacement leaf springs where legal in NHRA stock class cars. They diffinitly made a difference on that car on those springs, I have since used them on SS springs on a 440 motor A body bracket car, that car liked the clamps on every leaf on the front half and one on the back half right behind the rear end, 1st or 2nd leaf behind the rear end, I can't remember which Make up a bunch of them with the proper 3/8 bolt lengths for the different locations on the springs so you can add or removed them at the track to get the best 60 ft. times, make sure and install them with the cars weight on the springs, preferrably with someone in the drivers seat that is similar in weight to you Another thing you may want to try is to remove the plastic pads (insulators) from the springs also, that usually requires disassembling the springs to get all of them out That is worth doing on a race car that your trying to get every hundred of a second out of
[Re: Dart1031]
#551068
12/12/09 08:02 PM
12/12/09 08:02 PM
Posts: 20,818 A collage of whims
topside
A collage of whims
Made my own years ago as well; my car likes 2 per side in front, and seems to prefer no clamps on the rear section. 1.5 x 4.5, 3/8 plate, 3/8 holes 3.00 to 3.25 apart, and a couple different lengths of 3/8-16 or 3/8-24 bolts with washers & locking nuts, and you're good to go. Drill them in pairs, clamped together, using a drill press, chamfer any sharp edges, and paint 'em, and you're done.
[Re: topside]
#551069
12/12/09 08:10 PM
12/12/09 08:10 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
does the seperation of the rear leaf segments aply more pressure to the rear tire?
[Re: topside]
#551072
12/12/09 08:32 PM
12/12/09 08:32 PM
blownzoom440
ELYRIA,OH
Storm, it seems to apply the tires better on my car, a couple hundredths quicker to 60' on a moderately-grippy track. Other guys have had the opposite experience with their cars, though.
i have been debating this for a while.when i baught the springs from mancini thay said not to remove the bands.[heavy car,lots of TQ.]
[Re: blownzoom440]
#551073
12/13/09 04:55 PM
12/13/09 04:55 PM
Posts: 1,552 Michigan
Kiddart
how would the front segment clamped with slider box in the rear. any one now if that would work or not
Thank you Kiddart
[Re: Kiddart]
#551074
12/13/09 05:03 PM
12/13/09 05:03 PM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
I have a bunch of bend over type spring clamps I`ll sell cheap if anybody needs them. I got them from a spring shop and don`t need them since I have mono-leafs and Cal-Tracs.
[Re: topside]
#551075
12/13/09 06:10 PM
12/13/09 06:10 PM
Kudakidd
sounds like a plan!
[Re: Kiddart]
#551076
12/17/09 10:45 AM
12/17/09 10:45 AM
Kiddart
how would the front segment clamped with slider box in the rear. any one now if that would work or not Anyone know?? Monte you out there??? Kiddart
Thank you Kiddart
[Re: Kiddart]
#551077
12/25/09 10:23 PM
12/25/09 10:23 PM
Kiddart
Ok guys, this is my christmas presents. Spring relocation kit Slider boxs Back brace for rear end In the this post I added the question, If I use the clamps on the front segment and one on the rear segment somewhat loose would a slider box help out as well. I want to go to a mono leaf rear but the funds arnt there as of right now. what are the opinions on the items. Again this is a super stock spring application. I guess my thought is if I use the clamps on the leafs that more less makes a mono leaf, right? wrong? I guess I am in need of some smart guys opinions. my friends that run the compleete caltrac run the slider boxs and with good results. any suggestions are very welcomed Thanks guys
Thank you Kiddart
