Re: Leaf Spring Clamps - Anyone Use Them?
[Re: Kiddart]
#551074
12/13/09 05:03 PM
12/13/09 05:03 PM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
I have a bunch of bend over type spring clamps I`ll sell cheap if anybody needs them. I got them from a spring shop and don`t need them since I have mono-leafs and Cal-Tracs.
[Re: topside]
#551075
12/13/09 06:10 PM
12/13/09 06:10 PM
Posts: 7,861 Witness Protection Program
Kudakidd
Made my own years ago as well; my car likes 2 per side in front, and seems to prefer no clamps on the rear section. 1.5 x 4.5, 3/8 plate, 3/8 holes 3.00 to 3.25 apart, and a couple different lengths of 3/8-16 or 3/8-24 bolts with washers & locking nuts, and you're good to go. Drill them in pairs, clamped together, using a drill press, chamfer any sharp edges, and paint 'em, and you're done.
sounds like a plan!
[Re: Kiddart]
#551076
12/17/09 10:45 AM
12/17/09 10:45 AM
Posts: 1,552 Michigan
Kiddart
how would the front segment clamped with slider box in the rear. any one now if that would work or not Anyone know?? Monte you out there??? Kiddart
Thank you Kiddart
[Re: Kiddart]
#551077
12/25/09 10:23 PM
12/25/09 10:23 PM
Kiddart
Ok guys, this is my christmas presents. Spring relocation kit Slider boxs Back brace for rear end In the this post I added the question, If I use the clamps on the front segment and one on the rear segment somewhat loose would a slider box help out as well. I want to go to a mono leaf rear but the funds arnt there as of right now. what are the opinions on the items. Again this is a super stock spring application. I guess my thought is if I use the clamps on the leafs that more less makes a mono leaf, right? wrong? I guess I am in need of some smart guys opinions. my friends that run the compleete caltrac run the slider boxs and with good results. any suggestions are very welcomed Thanks guys
Thank you Kiddart
