Question about installing new spring perches #551052
12/11/09 12:52 PM
12/11/09 12:52 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I am going to be removing my 8 3/4 rearend to have new spring perches installed for the offset spring kit I am going to be using. When having the new spring perches welded on, is it necessary to drain the rearend fluid and remove the axles from the rearend housing?
Re: Question about installing new spring perches [Re: 1970RT] #551053
12/11/09 02:36 PM
12/11/09 02:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No, might want to have a wet rag handy to cool the axle housing so you don't cook the seal inside.
