Re: Aluminum radiator mounting
[Re: 67dodgeracer]
#550676
12/11/09 12:23 AM
12/11/09 12:23 AM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
What's the best way to mount an aluminum radiator without mounting tabs?Any examples you can show me?
Havent you ever looked in the old mans new Dart that replaced the Hairy Canary?...LOL
[Re: Chassisman]
#550678
12/11/09 12:30 AM
12/11/09 12:30 AM
Posts: 2,524 PA
moparacer
PA
I set mine on pins and set them in the holes that are in the bottom of the factory core support.
90s Dodge Dakota rubber mounts fit the holes perfect.
Will get some pics of my rad tomorrow if I get the chance.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: topside]
#550680
12/11/09 12:43 AM
12/11/09 12:43 AM
Posts: 4,247 Newfoundland
codfish
Newfoundland
This is how I mounted mine. I used straight brake line as spacers, and 1/4" bolts. Cheap and easy. codfish
[Re: codfish]
#550681
12/11/09 12:47 AM
12/11/09 12:47 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Cheap and easy.
codfish
Nice
[Re: topside]
#550683
12/11/09 01:12 AM
12/11/09 01:12 AM
Posts: 52,972 Romeo MI
MR_P_BODY
On mine, I used some aluminum channel for the bottom, so it sits in a "saddle" like a GM car or truck; then I fabbed 2 aluminum "L" brackets to hold the top. Some foam rubber strips insulate the radiator from the saddle & brackets. Light weight and easy to pull the radiator if needed. The saddle mounts to the bottom of the radiator support, and the top brackets are mounted to the upper tie bar (aka upper yoke).
This is pretty much how I did mine but since it leans back quite a bit the top has a bracket on the rad and I use a strut back to the engine... I also use 2 brackets as clamps on the bottom to hold it down
[Re: Al_Alguire]
#550684
12/11/09 01:13 AM
12/11/09 01:13 AM
WILD BILL
BROOK PARK, OH
Enlarged it for ya Al.
[Re: Chris'sBarracuda]
#550691
12/11/09 01:58 PM
12/11/09 01:58 PM
Posts: 136 CHANDLER, AZ
512 VALIANT
CHANDLER, AZ
I mounted mine with tubing, then put pins on the crossbar. Held on by clevis pins for easy removal..
Chris..
Good idea
[Re: 67dodgeracer]
#550692
12/11/09 02:02 PM
12/11/09 02:02 PM
Posts: 1,880 USA
Ron Silva
USA
I use 2 pieces of aluminum angle at the top to attach/hang the readiator to the core support and then use 1/4" bolts with spacers at the bottom to pull it up to the core support.
SRT DEMON ONE SEAT
[Re: 67dodgeracer]
#550693
12/11/09 02:03 PM
12/11/09 02:03 PM
Chassisman
Chowchilla,ca
Chassisman,I haven't seen under the hood of the dart,just the tailights.
It's funny...the older he gets the faster he wants to go...he said for his 70th B-Day he wants to go in the 7's...LOL
