bellhousing #548745
12/08/09 03:29 AM
12/08/09 03:29 AM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
i am desperately searching for a bellhousing for my engine swap with no luck. i have been scavenging the local yards trying to find a vehicle that has a LA small block mated to a A833 OD tranny with no luck. Can someone tell me if there are any other trannies that might be bolted to the same bellhousing? Or is does it have to be a A833 OD only? is there such a thing as an A833 OD/LA318 bellhousing? i am pulling my slant six in favor of a 318, and wanted to keep my A833 OD. This is crippling my engine swap, please help!
Re: bellhousing [Re: '84 D150 Shorty] #548746
12/08/09 04:28 AM
12/08/09 04:28 AM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
They are out there but they arent that common. Most V8 trucks had the big heavy cast iron tranny behind their engines. I was lucky enough to nab one from a member here years ago and I'm putting it to use in my '86 stepside project behind a 318 and in front of a cast iron A-833OD
Your best bet is to find a standard one and either have the hole milled out for the A-833 bearing retainer or have your bearing retainer (the big round thing that bolts to the front of your tranny with 4 bolts) turned down.
I'm not sure about bearing retainer specs, hopefully someone else can chime in with those soon.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: bellhousing [Re: MoPar Jamie] #548747
12/08/09 09:11 AM
12/08/09 09:11 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Does your clutch fork pivot on a ballstud or the more common clip type pivot? You will need to change the flywheel/clutch also. Both styles of SB O/D bells are 10.5". /6 Truck used a 9.5" wheel with a 10" clutch. We can set you up with the parts you need to do the swap.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: bellhousing [Re: 64dodge572] #548748
12/08/09 10:55 AM
12/08/09 10:55 AM
Southington, Ohio
dm69charger Offline
dm69charger  Offline
Southington, Ohio
I have a small block aluminum bellhousing laying around with a large bearing retainer opening. Let me know what the part number is and I will check it. I am more familiar with the big block stuff than the small block stuff.
Re: bellhousing [Re: '84 D150 Shorty] #548749
12/08/09 04:02 PM
12/08/09 04:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Any '76 or later car or truck with a SB and 833 will have the OD trans.
Re: bellhousing [Re: John_Kunkel] #548750
12/08/09 04:41 PM
12/08/09 04:41 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
also depends on if you want a mech or hyd clutch....
I am truckless..
Re: bellhousing [Re: 340SHORTY] #548751
12/08/09 04:55 PM
12/08/09 04:55 PM
scratchnfotraction Offline
I am looking for one too
Re: bellhousing [Re: '84 D150 Shorty] #548752
12/08/09 04:57 PM
12/08/09 04:57 PM
AndyF Online content
AndyF  Online Content
Buy a new bellhousing from QuickTime.
Re: bellhousing [Re: scratchnfotraction] #548753
12/09/09 01:31 PM
12/09/09 01:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
good to see this thinly veiled want ad x2 still going strong ... in the Q+A no less
Re: bellhousing [Re: JohnRR] #548754
12/09/09 01:34 PM
12/09/09 01:34 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Re: bellhousing [Re: badblack68] #548755
12/09/09 04:33 PM
12/09/09 04:33 PM
my bad
I PMed off line about it as well
guess it all in how you say it
was a for sales add to
Re: bellhousing [Re: badblack68] #548756
12/09/09 05:45 PM
12/09/09 05:45 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
go fish
1983
Transmission Bellhousing Only
Dodge Truck 150 Series COMPARE,681131 91130 $110 Lemons Auto Parts, Inc. USA-NC(Madison) Request_Quote 1-800-453-6667 Request_Insurance_Quote
2270
1981
S1-S1 10643 $74.18 B & F Auto Parts, Inc. USA-FL(Palmetto) E-mail 1-941-722-6279 2535
1984
Dodge Truck 150 8-318 (5.2L), 10-1/2"CL,STOCK NO. 001569059 001569059 $50 Phil's Auto Salvage USA-CO(Hotchkiss) E-mail 970-527-5656 943
1985
Dodge Truck 150 Series 318 MATCH SRE 12-07 09625 $Call Medford Auto Wreckers USA-NY(Medford) Request_Quote 1-631-289-1772 Request_Insurance_Quote
2437
1984
Dodge Truck 150 8-318 (5.2L), 10-1/2' cl A 9B46 $Call K & K Motors, Inc. USA-TX(Graham) Request_Quote 1-800-766-2009 Request_Insurance_Quote
I am truckless..
