Re: What is needed to convert to a challenger rally dash?
[Re: moparmojo]
#548596
12/08/09 12:02 PM
12/08/09 12:02 PM
Posts: 581 Texas
Texican
Texas
I converted a 71 Challenger (non Ralley) to a Ralley Cluster about 2 years ago and although it's not rocket science, there are a few things you must consider.
Questions: Do you want to convert to a 3-speed wiper motor at this time ? Do you want to keep your exisitng (non-ralley dash harness) ?
Either combination is a possibility...but with my conversion, I wanted to keep my existing (non-ralley) harness, but upgrade to a 3-speed wiper motor AND ralley guages.
If you upgrade your dash harness to a RALLEY HARNESS, the conversion will be (EASY) BUT you'll need to also changeout your wiper switch because the connector is completely different. But you can wire it individually using the Challenger wiring diagram.
If you buy a ralley dash harness, and ralley guages plus 3-speed wiper switch, you'll have no problems.
If you decide to use a (non-ralley) harness, then you'll need to do the following:
Loosen the steering column bolts from the dash frame so you'll have rrom to remove the cluster.
Pull old cluster and label all wires accurately including dash illumination lights, turn signals, brake, etc... (everything is compatable and will hook right up).
Move all wires according to where they go.
Be sure to take your time and be creative when it comes to moving the turn signals, bright light indicator, brake, and dash illumination lights...it may require adding a few additional dash illumination lights that were not on the non-ralley harness. You'll see what I mean when you get to that point -it's not difficult.
Then you'll hook up your Tachometer wire to ??? (depends on your setup...if you have MSD ignition, your factory Tach may not work and you might need to have your tach sent off to be setup for it...there are posts regarding how to make a tach work with MSD ignition).
Once everything is hooked up including sending units, power, ground, lights, etc... You'll need to start it up and test it. Be sure to test your turn signals, bright lights, dash lights, etc...
The whole conversion should take less than 2 hours.
Good luck
[Re: CokeBottleKid]
#548597
12/08/09 12:27 PM
12/08/09 12:27 PM
Posts: 1,527 minnesota
Kirby
minnesota
I wouldn't do it unless you have $$$
Wiring is different but more importantly is the bezels/surrounds
The drivers side vent/heater - A/C control goes for a couple hundred bucks... if you can find them..
I just converted my standard A/C panel to work with a ralleye panel. I used a corner from a cig pack, taped in place, and used bondo to make the corner that is missing on a standard ac panel. Used a dremel to shape it, and a little silver paint to reproduce the chrome edge. Sure if you look close you can see it- but it cost me about 2 bits to do it, and I'll bet few will ever notice.
