torqueflite question #547131
12/06/09 05:37 PM
12/06/09 05:37 PM
north carolina
K
kwik63 Offline OP
kwik63  Offline OP
K
north carolina
What would be the best way and what product or chemical would be needed to flush a torque converter? It is out of the car and the transmission has had no issues just normal clutch dust and wear.
Re: torqueflite question [Re: kwik63] #547132
12/06/09 06:03 PM
12/06/09 06:03 PM
scratchnfotraction Offline
check local tranz shop,some have a machine that spins and flushes them
could pick up a fresh reman one cheaply
I drain them in a bucket over night and refill and run them,when the are fairly clean to start with,IMO
Re: torqueflite question [Re: scratchnfotraction] #547133
12/06/09 06:13 PM
12/06/09 06:13 PM
EPA regs supposedly made the trans shops do away w the converter flushing machine. Run some solvent thru it, slosh it around then drain it & flush the solvent out completely w some new fluid & you're good.
Re: torqueflite question [Re: RapidRobert] #547134
12/06/09 06:21 PM
12/06/09 06:21 PM
Put a drain plug in it, makes it easier to change the fluid later too.
Re: torqueflite question [Re: kwik63] #547135
12/06/09 06:56 PM
12/06/09 06:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Once you see a used converter cut open you won't settle for less than a rebuilt.
Re: torqueflite question [Re: John_Kunkel] #547136
12/06/09 10:34 PM
12/06/09 10:34 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Go with a Dayco if it is just a stock deal
I want my fair share
Re: torqueflite question [Re: kwik63] #547137
12/06/09 10:41 PM
12/06/09 10:41 PM
Indiana
P
Pentastar440 Offline
P
Indiana
Don't forget to buy a flush kit to clean the transmission lines and the transmission cooler. Then blow them out good.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: torqueflite question [Re: SomeCarGuy] #547138
12/07/09 09:31 AM
12/07/09 09:31 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I agree.
Reman TC's (stock) are under a hundred bucks and
their 2400 stall TC's are under 250.
They're the biggest, by far, suppliers to the tranny rebuild shops.
Re: torqueflite question [Re: Commando1] #547139
12/07/09 10:01 AM
12/07/09 10:01 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Does Dayco have a website?
This is the land of the free because of the brave
Re: torqueflite question [Re: rbstroker] #547140
12/07/09 10:28 AM
12/07/09 10:28 AM
I get mine at the local tranny shop
they are consolidated converters or something..I have the box at home,I will look for sure
I have used a few of the dayco on the chebbys and pontirags..
got my /6 HS loc-up for a a999 for 120$
had them add a drain plug also
OH!,I have a dayco sticker on the tool box with there #,but when I called they referd me to a local tranny shop..they are a wholesale rebuilder or something..at least thats what the phone person said
dont think they have a web sight either
Re: torqueflite question [Re: scratchnfotraction] #547141
12/07/09 11:44 PM
12/07/09 11:44 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
dacco has stores in Tampa,Orlando,Pensocola,and I believe the Miami and Jacksonville area just call one they will most likely sell to you.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: torqueflite question [Re: RapidRobert] #547142
12/07/09 11:46 PM
12/07/09 11:46 PM
Kissimmee Fl.
Kissimmee Fl.
never had the EPA tell us anything about getting rid of our flusher we got rid of it because most of the units for the last 20 years have had some kind of luck up converter and it wasn't worth the gamble when a reman cost no more than they do
