Powdercoating a rear axle, who's done this?
#544792
12/04/09 02:58 PM
12/04/09 02:58 PM
Posts: 697 Central IL
70Sbird
Central IL
Hello, I scored a complete 8.75 A body axle assembly last weekend for my Demon project and now have the rusty/crusty/dirty mess mostly disassembled on my garage floor. I'm considering having the housing and spring/shock plates powdercoated. Any downside to this, and about how much should I be spending to have these parts blasted and coated? I've never had powdercoating done before and would like to know what I'm getting into if I go that route. I read the thread about protecting the threads, and this sounds like a good plan. Thanks! Scott
Re: Powdercoating a rear axle, who's done this?
[Re: 70Sbird]
#544795
12/04/09 04:36 PM
12/04/09 04:36 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
We're in Minnesota (JIT Powder Coating) but I can make a few recommendations on powder coating. You won't want to try powder coating a fully assembled unit. I can't tell you how many people have dragged in a fully assembled rear end here. Remove axles, seals, 3rd member, etc. Pressure wash the bare housing as best you can prior to blasting. If you want to do the 3rd member you'll need to remove the ring and pinion, pinion seal, etc. After blasting, everything needs to be washed and dried thoroughly prior to painting. Depending on how greasy the housing was it may be advisable to have it put in the cure oven for a half hour or more prior to doing anything else to see if any impregnated grease or oil will become viscous and bleed out. Much better to find out now that after it's painted. Don't go with a real high gloss black if that's the color you want. We recommend a 60 gloss black (Your powder coater will know what that means) which is a good compromise on appearance, maintenance and long term performance. If the housing is really pitted badly, you should discuss a primer coat being applied before the color top coat. This will make for a much smoother, 'new' looking housing. Don't let them go crazy putting a lot of powder on. 1.5 mils of primer and 2- 3 mils of color is plenty. Some people fall into the some is good, more is better trap. I don't recommend a clear coat. In this area we charge $175-250 for blasting, prime and color top coat of housing, spring perches and backing plates. Drums can also be done but the brake contact surface needs to be masked and that's labor intensive. 3rd member can be done too, but masking is involved here, so figure another $100-125 for 2 drums and 3rd member in the mix. The heat required to cure the powder will not warp or otherwise affect the housing. The ramp up of heat in the cure oven is not a problem and most powders only require 350-390 degrees F for up to 30 minutes to cure properly. Let the parts cool down on their own once through the cure oven. If you have other questions feel free to call us at 651-463-4664 or email JITPOWDR@AOL.COMGood luck with the project!
Lead, follow or get the hell out of the way
[Re: peabodyracing]
#544797
12/04/09 05:18 PM
12/04/09 05:18 PM
70Sbird
Central IL
Thanks! I will only be dropping off the empty housing, spring plates, and maybe the bare 3rd member. This housing is pretty rusty/pitted and am NOT looking for a really glossy show finish, just something durable that looks decent (probably Black or Gray). I'm thinking that there will be some agressive blasting to get all of the rust off the housing, since I'm assuming it will have to be completely rust free to coat but I also an guessing the coaters are used to dealing with this on chassis parts.
[Re: 70Sbird]
#544800
02/12/10 09:08 AM
02/12/10 09:08 AM
Posts: 2,836 Detroit boy in Saugerties, NY
BrianShaughnessy
Semi gloss black on a 8.75 housing was $90 at Technical Coatings in Kingston NY a few months ago. Blasting included.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana. Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart. El Grande: '98 Grand Cherokee 5.9 Limited.
[Re: BrianShaughnessy]
#544801
02/12/10 11:37 PM
02/12/10 11:37 PM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
mine was $25.00 to have the housing and backing plates sand blasted (thay use a fine sand) and was $50.00 to have them powder coated semi gloss black
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: demon440]
#544808
09/20/11 10:37 PM
09/20/11 10:37 PM
Posts: 63 Maryland
brianz426
Maryland
I'm back into this old post hoping some of you could chime in and help me. I had my 8-3/4 axle housing and end plates powder coated and they turned out great. My problem is getting the inside of the housing clean. They blasted and baked the housing and the inside looked clean and dry except for the dried grease/oil residue. I started with an industrial water soluble machine shop type cleaner degreaser. I thoroughly washed the interior with a brush. After it dried I cleaned the inside again with brake cleaner spraying until the cleaner ran out clean. I still feel a very fine grit when I touch the inside. How did you guys clean the inside of your housings? Do I need to keep cleaning until all interior surfaces feel smooth? Should I try pressure washing the inside. I definitely want all the grit out before I reassemble everything. Thanks
[Re: brianz426]
#544810
09/21/11 08:48 AM
09/21/11 08:48 AM
Challenger 1
Cincinnati, Ohio
Steam pressure washer kicks azz when it comes to heavy oil and grease removal. This tool has saved me me countless hours. Perfect for cleaning the inside of a axle housing.
