Problem solved #542241
12/01/09 05:53 PM
12/01/09 05:53 PM
Q
Quicktree Offline OP
Q
THANKS to Dan (DRAM). he told me to put a blue pump cam in it. and I do believe he was right. I had the pink cam in it and was having the tip in issue. the pink cam took about a quarter of turn on the throttle to get the squirters started. if you look at the 2 cams the blue cam starts the squirter as soon as it moves. I doubt I would have ever thought about that cam in a million years. I have never used one on any application. haven't got on the road with it but I can't make it hesitate like it did at idle. so lets cross our fingers.. thanks again DAN
Re: Problem solved [Re: Quicktree] #542242
12/01/09 05:54 PM
12/01/09 05:54 PM
Q
Q
Re: Problem solved [Re: Quicktree] #542243
12/01/09 05:56 PM
12/01/09 05:56 PM
under a rock
flathood Offline
flathood  Offline
under a rock
Nice pic
Re: Problem solved [Re: Quicktree] #542244
12/01/09 06:23 PM
12/01/09 06:23 PM
Was the spring loaded plunger bolt adjusted correctly, .015 or more clearance between the pump arm and the pump plunger bolt at WOT? if not try that
Re: Problem solved [Re: flathood] #542245
12/01/09 06:35 PM
12/01/09 06:35 PM
organ
maximum entropy Offline
organ
Nice pic
they say a picture is worth a thousand words. they also say there is an exception to every rule.
Re: Problem solved [Re: Cab_Burge] #542246
12/01/09 06:57 PM
12/01/09 06:57 PM
Q
Q
yea I adjusted them after each change.
Re: Problem solved [Re: Quicktree] #542247
12/01/09 08:35 PM
12/01/09 08:35 PM
408Dust Offline
408Dust  Offline
Re: Problem solved [Re: 408Dust] #542248
12/01/09 08:45 PM
12/01/09 08:45 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Good to Hear Tony,,sometime's it's the simplest of things that are the one's that give you the biggest fit's.
Re: Problem solved [Re: dartman366] #542249
12/01/09 09:18 PM
12/01/09 09:18 PM
good call.DRAMS THE MAN!!!!!
Re: Problem solved #542250
12/01/09 09:26 PM
12/01/09 09:26 PM
Q
Q
yep DAN is one of the few builders who shares his knowledge with us. wether you buy from him or not. thats why he will get my business when I can
also thanks to Brian and the rest of the moparts members who have tried to help. sometimes it takes many ideas to come up with something that works
Re: Problem solved [Re: Quicktree] #542251
12/01/09 09:31 PM
12/01/09 09:31 PM
couldn't have said it any better.
Re: Problem solved [Re: Quicktree] #542252
12/01/09 09:33 PM
12/01/09 09:33 PM
Q
Q
and for some more info, the 750 based proform that I had on this motor probably didn't give me as much trouble because I ended up with brown cams on it. if my memory was worth a flip I should have remembered that
Re: Problem solved [Re: Quicktree] #542253
12/01/09 11:30 PM
12/01/09 11:30 PM
i'm glad i could help, after all, that's the main reason i hang around this place. i post much less frequently than i used to and do most of the helping by PM or phone calls now. i guess that's very evident to many.
regardless, sometimes it's the easy and overlooked things that are the problem. let's hope that solves the problem. by the way, there are other pump cams available with different ramp rates that might also work, especially if you find the blue cam is just a touch too aggressive. just let me know.
Re: Problem solved #542254
12/02/09 07:21 AM
12/02/09 07:21 AM
Q
Q
don't stop posting Dan, more people listen and learn than you think
Re: Problem solved [Re: Quicktree] #542255
12/02/09 07:58 AM
12/02/09 07:58 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Thats great, I was feeling your pain
