Re: Dakota spindles on 73 clubcab done (almost)
[Re: ramblebee]
#54125
03/03/08 08:38 PM
03/03/08 08:38 PM
I don't see how that the spindles can be wrong. I comapared between the two sides of my truck one side with drop spindle and one side not, and the rotor is sticking up past the upper control arm on the side wth the drop spindle and it is about two inches bellow the upper control arm on the side with the stock spindle so I know that it dropped my truck. The spring is holding it up. Where does every one else get their drop springs from. I can see that I am probbly gonna have to shop somewhere else.
#54126
03/03/08 08:47 PM
03/03/08 08:47 PM
Posts: 248 Amarillo, Tx
ramblebee
Amarillo, Tx
There is a member that posted on here the other day about bolt on lowering kits and he has springs as part of the kit.I know Chisholm discontinued the arms but not sure on springs.I went back with stock springs.
[Re: ramblebee]
#54127
03/03/08 08:52 PM
03/03/08 08:52 PM
So you got the drop from your spindles and lower control arms.
#54128
03/03/08 08:54 PM
03/03/08 08:54 PM
ramblebee
Amarillo, Tx
Yes, I put uncut stock coils back in.
[Re: ramblebee]
#54129
03/03/08 09:05 PM
03/03/08 09:05 PM
I'm thinking that I want to go another route with this, i like the idea of having the original springs in my truck because I hate the way it drove with cut coils. I know it drives good with the originals so I think I will folow in your tracks and try to find a good set of lower control arms. Can I ask how much drop you got from your lowers?
#54130
03/03/08 09:16 PM
03/03/08 09:16 PM
ramblebee
Amarillo, Tx
Im not positive how much drop I got.Now that everything has settled I measure 13" from center of wheel to fender lip.I think Chisholm claimed 2" drop for thier arms.
[Re: ramblebee]
#54131
03/03/08 09:31 PM
03/03/08 09:31 PM
I have emailed the person on here selling the bolt on lowering kit inquiring about thier lower control arms. I want to thank you for the help. I hate to be the guy who doesn't research his own stuff but it seems that you already had it figured out, so maybe I'll be able to help you on your next prodject as much as you and the others have helped me on this one.
#54132
03/03/08 09:47 PM
03/03/08 09:47 PM
ramblebee
Amarillo, Tx
Im blushing. Glad I could help
[Re: 76dodgeboy]
#54134
03/03/08 10:26 PM
03/03/08 10:26 PM
They don't work as drop springs what would you want them for?
[Re: 76dodgeboy]
#54135
03/03/08 10:27 PM
03/03/08 10:27 PM
ramblebee
Amarillo, Tx
Do you want to get rid of your old springs?
I tossed them out yesterday.You wouldnt have wanted them, they didnt ride very good.
[Re: 76dodgeboy]
#54137
03/03/08 10:45 PM
03/03/08 10:45 PM
Sorry I thought you were talking to me
[Re: 76dodgeboy]
#54139
03/03/08 10:53 PM
03/03/08 10:53 PM
I should be paying better attention I do remember you post and do appreciate the input.
#54140
03/04/08 07:59 AM
03/04/08 07:59 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
84, it sounds like that guy is really feeding you a line of ****.
My spindles have shipped, but while i was under redoing the exhaust, i noticed im going to need new rubber lines, probably new hardlines, and maybe calipers if the bleeders dont open up, so unfortunatly im going to have to wait a little bit on the swap as i might need to get tierod ends and what not too.
I am most likley just going to get new stock spring and use the spindles, i dont want to go as low as you guys are doing.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#54141
03/04/08 08:04 AM
03/04/08 08:04 AM
85_Ram_4speed
Ramblebee, are the '85 truck outer tierod ends the same taper as the dakota ones---what does your little moog book say? If so i may be able to get away with just new adjuster sleeves.
Does it have spring specs too? I thought it was said a 90-93 spring was a touch shorter than would be for 89 and earlier.
I know my ball joints are the same as the dakotas so that is a non issue as of right now.
Outcast Dodge guy.
