Re: Sb with main studs and oil pump clearance?
[Re: Thread Ender1]
#540992
11/30/09 01:02 PM
11/30/09 01:02 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I cut and chamfer the stud, and spot face ( mill) the pump stud boss area down on the pump housing.
RIP Monte Smith
[Re: aarcuda]
#540994
11/30/09 02:22 PM
11/30/09 02:22 PM
Posts: 1,178 Indy
FlyFish
Indy
I cut the stud down, ground down the 12 pt nut and the pump for clearance with no washer.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: aarcuda]
#540995
11/30/09 03:39 PM
11/30/09 03:39 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
i just ran the regular bolt for that cap
Same here.
[Re: FlyFish]
#540999
11/30/09 10:36 PM
11/30/09 10:36 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
I had the machine shop deal with it and they did the above to solve the problem.
[Re: justinp61]
#541001
12/01/09 11:06 PM
12/01/09 11:06 PM
Posts: 486 IL
knyech1
IL
Same here.
same here
