1969 383 firing order question. #539774
11/29/09 12:16 AM
11/29/09 12:16 AM
Fort Bragg, California
O
otto37 Offline OP
otto37  Offline OP
O
I just purchase by first Mopar! A 1969 Dodge Super Bee. I would like to adjust the time using a timing light. The engine is the original 383, with aftermarket intake manifold. Which cylinder is the Number ONE?
Thanks, Mike
Re: 1969 383 firing order question. [Re: otto37] #539775
11/29/09 12:21 AM
11/29/09 12:21 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Number One is the left hand/front cylinder, and welcome!
Re: 1969 383 firing order question. [Re: otto37] #539776
11/29/09 12:21 AM
11/29/09 12:21 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Drivers side.
firing order is 18436572
I want my fair share
Re: 1969 383 firing order question. [Re: SomeCarGuy] #539777
11/29/09 12:26 AM
11/29/09 12:26 AM
O
otto37 Offline OP
otto37  Offline OP
O
Thanks for the fast replies!
Can you further explain this:
"Drivers side.
firing order is 18436572"
Does that mean Drivers side front of car to back 1843
and Passengers side front of car to back 6572?
Thanks, Mike
Re: 1969 383 firing order question. [Re: otto37] #539778
11/29/09 12:33 AM
11/29/09 12:33 AM
SomeCarGuy Offline
SomeCarGuy  Offline
odds on drivers side
evens on pass
Re: 1969 383 firing order question. [Re: otto37] #539779
11/29/09 12:36 AM
11/29/09 12:36 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The cylinders are 1357 front to rear on drivers side, and cyls on passenger side are 2468 front to rear. The firing order is 18436572 and those are going around the distributor cap in a counter-clockwise direction. Any better?
Re: 1969 383 firing order question. [Re: buildanother] #539780
11/29/09 01:48 AM
11/29/09 01:48 AM
O
otto37 Offline OP
otto37  Offline OP
O
Thanks for explaining!
Mike
Re: 1969 383 firing order question. [Re: otto37] #539781
11/29/09 02:16 AM
11/29/09 02:16 AM
SomeCarGuy Offline
SomeCarGuy  Offline
FYI, you can usualy run anywhere from 8-14 initial time on these engines. Check you total advance and see how much is in the distributor. 36-38 is pretty much max.
I've been running 14/38 in my stock 383 and it has done well but I'm considering going back to 10/34 since I just cruise around. Engine seemed to be happier with that setting, ran smoother I think. Gas mileage isn't any better with the extra timing either so...
Be sure to run a lead additive if you are unsure if the heads have been updated with hard seats and make sure to run oil with zinc or you will most likely wipe the cam. You can get an additive or Valvoline ZR1 has it in there already. One of the few like that that the parts stores carry. Might have to have them order the kind you want if you don't want 20W-50
