Re: 0.008" thrust bearing clearance - run it or weld it?
[Re: solidlifter]
#538992
11/28/09 05:04 PM
11/28/09 05:04 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
i'm on the fence here. thrust bearing clearance came out at 0.008" and i'm wondering is i should go with it or have the crank welded up. it is a 4.15" eagle that is going in a 12.2 CR/EZ-295/solid roller engine. any thoughts?
Still Ok but close to the high side. My old 496 was like that. It never got worse. I could actually feel the crank move back and forth when I pulled the crank back and forth
[Re: 602heavy]
#538994
11/28/09 09:54 PM
11/28/09 09:54 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
It's on the limit but nothing to worry about , i ran the clearance @ .013" & had no issues , i've since found a guy that does white metal work on these bearings , sent the bearing away & had him add .008" to the rear thrust face of bearing , cost £40.00 , which is around $70.00.
i was wondering if some1 did that but thaught the layers would seperate maybe.
[Re: Cab_Burge]
#538996
11/29/09 01:49 AM
11/29/09 01:49 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I have run them as loose a .009 and as tight as .003, although not idea...I had no problems..These were pretty healthy race engines..one making 900hp.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Mcode69]
#538998
11/29/09 08:09 AM
11/29/09 08:09 AM
Posts: 872 NJ
SSDAcuda
NJ
Clearance should be .007 to .009, .008 is perfect! I wouldn't worry looser, its tight that will get you.
SS/DA 1924
