Re: 440 engine heads/springs [Re: roy2345] #537875
11/28/09 06:32 PM
11/28/09 06:32 PM
scratchnfotraction Offline
I would put a timming light and vac gauge on it to see where its at
Re: 440 engine heads/springs [Re: scratchnfotraction] #537876
11/28/09 06:51 PM
11/28/09 06:51 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
magna flow or Flowmaster, Dynomax? Which do you think?
Re: 440 engine heads/springs [Re: roy2345] #537877
11/28/09 06:51 PM
11/28/09 06:51 PM
resonators are extra muffs that are on the tailpipes as they pass parallel by the leaf springs. many diff types & (want no neckdown on the ends where the nipples connect to the body and louvers punched from the inside to the outside). On the regular muffs further upstream there have been good reviews here on the "hemi" dynomax super turbos. What Scratchnfotraction said on your timing put a light on it & see where you're at.
Re: 440 engine heads/springs [Re: RapidRobert] #537878
11/30/09 02:32 PM
11/30/09 02:32 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
thanks my friend! I'm on it today when I get off work. I checked last night and it looked like 36 degrees
Re: 440 engine heads/springs [Re: roy2345] #537879
12/03/09 10:00 AM
12/03/09 10:00 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
i was told that although my block is casted in 70 that it may be a 71 440 due to it being casted after June. HELPPPPPPPPPPPPP!
Re: 440 engine heads/springs [Re: roy2345] #537880
12/03/09 10:59 AM
12/03/09 10:59 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yes the blocks typically took 4 to 6 months from the casting date to being assembled motors installed in cars. sine the 71 model year cars would have started assembly in August it's safe to say they will be 71 check the vin on the motor at the back above bell housing
Re: 440 engine heads/springs [Re: scratchnfotraction] #537881
12/18/09 04:59 PM
12/18/09 04:59 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
What is the HP rating for a stock 440 engine out of a 1970 NewYork Chrysler
Re: 440 engine heads/springs [Re: roy2345] #537882
12/18/09 06:23 PM
12/18/09 06:23 PM
350
