Re: 440 engine heads/springs
[Re: roy2345]
#537877
11/28/09 06:51 PM
11/28/09 06:51 PM
RapidRobert
resonators are extra muffs that are on the tailpipes as they pass parallel by the leaf springs. many diff types & (want no neckdown on the ends where the nipples connect to the body and louvers punched from the inside to the outside). On the regular muffs further upstream there have been good reviews here on the "hemi" dynomax super turbos. What Scratchnfotraction said on your timing put a light on it & see where you're at.
