Can you pull the oil pan
#536891
11/26/09 01:13 AM
11/26/09 01:13 AM
Posts: 1,018 Missouri
MOBodyman
Missouri
on a '67 Polara 383 without pulling the motor? I need to replace the pan gasket. Can the motor be jacked up enough to do the job? Does the radiator need to come out? Any help/advice is appreciated. TIA, Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Can you pull the oil pan
[Re: WILD BILL]
#536893
11/26/09 09:09 AM
11/26/09 09:09 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
You probally need to drop the center link.I unbolt them and swing it up under the K frame.Then I jack the motor up and the pan comes out.A couple of the bolts are a little tough to get to but they can be reached.Check the fan to rad clearance and shrouud if you have one.I usually raise the engine on the pulleys with a block between them.Then just weasel the pan out.Rocky
Chrysler Firepower
[Re: therocks]
#536894
11/26/09 10:30 AM
11/26/09 10:30 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
yes can it be done... need to drop the center link... myself I have done raising the engine on tranny hump with a plywood in between, to not hoist the engine from top ( I don't have the place to raise the engine with hoist )
[Re: NachoRT74]
#536895
11/26/09 11:28 AM
11/26/09 11:28 AM
Posts: 3,380 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
It probably can be done with the centerlink dropped but that big fat c-body crossmember may make it hard to get to some of the front bolts. We just put the motor back in my brother's 67 Polara 383 last weekend and it was EASY to pull and re-install. If you can get a hoist it might just be easier to yank it P.S. Where you at in MO?
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#536896
11/26/09 01:52 PM
11/26/09 01:52 PM
Posts: 388 St. Louis, MO
BevoHoosier
St. Louis, MO
he's near ft. leonard wood IIRC
...and yeah, you kind of have to witness a big fat c-body crossmember first-hand to realize that it's really just going to be easier to hoist the damn thing out of there.
BMW
67 Dodge Polara 383
[Re: DaytonaTurbo]
#536898
11/26/09 02:41 PM
11/26/09 02:41 PM
therocks
Niles , Ohio
I have an 8 qt on my 65 with windage tray.I can still get it in and out.I just 3M the gaskets to the tray and then slip the pan in.Its tight but it goes.Rocky
Chrysler Firepower
[Re: therocks]
#536901
11/28/09 03:28 AM
11/28/09 03:28 AM
Posts: 21,645 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
We did a pan swap on a 68' fury and was a real pain. Jacked the car up on stands, unbolted the motor mounts, tranny mounts, lower exaust tubes,center link, then used engine hoist to pull the motor high enough to slip the pan out. It took all day with our big, meaty pans, but it worked great and still hold the seal on the new pan.
