Re: Duster hits the wall @ ETown, what a shame
[Re: WILD BILL]
#534932
11/24/09 02:56 PM
11/24/09 02:56 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
three bulbs were lit..i counted 9 seconds or so..i believe its 7 and your out.
somone mention'd he stayed in it too long. actually i feel he was trying to recover.. its hard to tell...fwiw tall gears create alot of engine braking.. if you can get the rear wheel speed back to the chassis speed you can often regain control.. i believe thats similar to what you where hearing.. same thing on the camaro...fwiw..but its conjecture at this point.
shame thats a nice duster.. cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: moparts]
#534933
11/24/09 04:43 PM
11/24/09 04:43 PM
Quicktree
From the video.. the Duster sat with the top bulb lit for quite some time, while the Camaro was acting stupid..
What would have happened if the Duster lit the 2nd bulb instead of waiting??
Not much would have happened, but he would have gotten his point across. I would have backed out and started my whole routine over.
Most times at Etown, they WILL back the staged car back out and make both cars pre stage before any stage. But then again on this run they also did not have the auto start on like they usually do. because with the long stageing of that chevy it would have been red lighted if they did.
not really auto start doesn't start untill both top lights and one bottom bulb is lit.
Post deleted by Defbob
[Re: Quicktree]
#534937
11/24/09 07:59 PM
11/24/09 07:59 PM
#534938
11/24/09 08:48 PM
11/24/09 08:48 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
This could happen to anybody.
That said problems started as soon as the front tires touched the ground. Judging by the bleacher view video the car sit low in the front.
Can't be sure, may not be the case here, but. Many times I have seen this and the top ball joint is way above the A-arm mounts. The car stands up and front end geometry goes nuts. Just because the torsion bars are adjustable doesn't make it a good idea to lower the front end. Appears the car had travel limiters on it which should have helped. Otherwise probably got out of it a little too late.
Easy to be Monday morning quarterback. Sorry it happened.
[Re: B1KILLER]
#534939
11/24/09 09:28 PM
11/24/09 09:28 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
The Chevy guy is a noob, but a red herring none the less.
This looked like a typical T&T night. the tracks do not prep the track or check the track for water, oil, etc.
As for the track personnel, what make you think they know what they are doing? For the most part, they don't unless its a big $$ event. Even then, I have had my breath taken away with some of the ignorance I have seen over the years.
Its a night time run. Below the dew point? a quick look at the sheet metal would tell you this.
I feel badly for the Duster, but if you have a 9.5 or better car, you have to deal with these contingencies.
8.30's @3400 lbs
