Re: PRH pump gas 572 dyno results
[Re: Streetwize]
#534375
11/26/09 01:23 PM
11/26/09 01:23 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
the 337 must be better than it looks.
That's what Dwayne said. The runner volume on the DP is larger so it wasn't as responsive to throttle position change as the 337 was. It's one of those things that might not show up on the dyno but would be noticable in the car....especially a 4100lb Tank.
I'm anxious to see those sheets as well !
Ron
[Re: Old School]
#534381
11/26/09 07:47 PM
11/26/09 07:47 PM
firefighter3931
Ontario,Canada
ron,the k&n setup i use is the K%N flow control.it has the biggest drop at 1.938".it is 16"x3.5".part # 61-4500.yours still might fit thou.but if not try this one.you can google k&n flow control for all the info.
Thanks Brian...just wondering if your car has a 2 speed wiper motor ? Mine does and it sticks out from the firewall....might not clear a 16in air cleaner assembly ?
Here's a pic of my current setup
Ron
[Re: mopar65]
#534382
11/26/09 07:59 PM
11/26/09 07:59 PM
firefighter3931
Ontario,Canada
Wow ron you are going to have to change the name of your car to The super black pig Sorry i missed you at MMW. So what are you going to do with the old 440 engine that the 572 is replacing?? . Mopar65
Hi Bobby...we missed ya at Monster Mopar !
I'm thinking about dropping the 440 into my 70 r/t and installing a stick. No plans to race that car but i'd like to have some fun and have never owned a 4spd Musclecar.
Ron
[Re: Old School]
#534384
11/26/09 09:59 PM
11/26/09 09:59 PM
firefighter3931
Ontario,Canada
ron,mine has a 3 speed wiper motor.is that your red 70 charger in the pic? man thats nice.i have 4 speeds in all of my cars.not the best for racing,but alot of fun to drive.i would not give up my man pedal for nothing..
That's what i figured Brian...the 2 spd wiper motor is close to the 14in diameter air cleaner assembly. Not sure if the 16in unit would clear...the extra 2 inches of diameter could be a problem. The big 6-pack air cleaners require a 3 spd wiper motor.
Yep, that's my 70....originally a plum crazy car with white interior/white vynil top and white butt stripe & V21 hood blackout treatment. Car is now Red with black interior changed over by previous owner. It's loaded with PS, PB, PW, Cruise control etc...I'm gonna keep it red and install the butt stripe and have the hood blacked out. I have some torque thrust D's and BFG's for it as well. Check out the photochop...looks good with the steelies but i think the TT D's would look nicer.
Thanks for the wiper motor info !
Ron
[Re: Streetwize]
#534386
11/26/09 10:23 PM
11/26/09 10:23 PM
firefighter3931
Ontario,Canada
I'd also like to see the printout of the 2D dual plane, especially interested in the "under the curve" torque.
Here ya go Bobby. It did well but not as good as the 337
Ron
[Re: BradH]
#534387
11/26/09 10:28 PM
11/26/09 10:28 PM
firefighter3931
Ontario,Canada
Is Dwayne going to provide you w/ any more dyno sheets? I'd be interested in seeing how the air/fuel curve looks w/ the QF 1050 carb after his final adjustments.
Here ya go Brad...best run with warmed up oil
Ron
[Re: BradH]
#534389
11/27/09 02:07 PM
11/27/09 02:07 PM
firefighter3931
Ontario,Canada
Thanks for the additional info.
You're welcome Brad....hope it helps
A couple more for Bobby ; first up the ICH DP with 1/2in open spacer
Ron
[Re: BSB67]
#534392
11/27/09 06:30 PM
11/27/09 06:30 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
The 337 was better overall in this test, no doubt, I just wish Ron could try my modded Indy Dual plane back-to-back and then with about a 100cfm bigger Lung (like my 1000hp or your Quick-fuel) to maybe 'even the playing field' for the dual plane Dual planes really need that larger carb cause you really have 2 motors with half the cubes and half the carb on a common crankshaft....I know that the upper plenum was making more power than the unmodded lower. My 517 felt like a completely different motor once I took the intake off to port it...especially over 4500RPM. Thanks so much for taking the time to post all the data...this definately needs to go to the Tech Archives!!!
[Re: firefighter3931]
#534393
11/28/09 08:07 AM
11/28/09 08:07 AM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Nice Ron! 68's are the best looking Chargers (I think). Wow, 4100 lbs, you must have the spare tire and tool box in the trunk. I would bet low 10,s with that much HP & TQ.
Next will be the idea spinning in your head, maybe just a little juice to hit that 9 sec zone once. That's if it doesn't make it on just the motor. Have fun on the street, and buy stock in a tire company!
Thanks BDS...that is the raceweight (4100) The BP weighs in at 3850 with a full tank of fuel (18 gallons) and the car is complete with full interior, heater, wipers, frame connectors and 8pt rollbar...it's a TANK !
Ron
I guess we all call our big cars (Tank)!
Keeping everything under the stock hood is cool. My Jason Line (Line Performance) built 440 ran a M-1 intake, and pushed my 4000 lb. pig or (tank) to 11.16 at 118. I was thinking real hard about a tiny shot of juice
Snap your neck, mega G-force launch, is all I want!
