Re: PRH pump gas 572 dyno results
[Re: firefighter3931]
#534335
11/23/09 05:16 PM
11/23/09 05:16 PM
Posts: 31,025 Oregon
AndyF
That is fairly consistent with what I've seen between those intakes also. The 337 does pretty well considering that it is such a low profile intake. It isn't going to be a high rpm intake on a big motor but it does just fine for this type of application.
Another intake in the mix would be the new Super Victor from Edelbrock. It is a tall intake so it wouldn't fit under your hood but it is a good one to compare to the Indy and 337. On my 505 motor the 337 and Super Victor were dead even.
Is that 1050 QF carb a 4500 style carb? So the 1 inch spacer is a spacer/adapter? For street use a 4150 carb might work better even though you'll give up a little top end power. Just another thing to play with. Looks like Dwayne's carb is putting up good numbers. I'd think that a Holley 1000 HP would work pretty well on that motor.
Edit - I see that the 1050 is in fact a 4150 carb so you should be good to go. A Dominator on an adapter would pick up some power for you if you ever feel the need for more power!
[Re: 5126brl No more]
#534337
11/23/09 05:21 PM
11/23/09 05:21 PM
AndyF
Will that 337 intake work on a RB with Bulldog heads?
I've never seen a set of Bulldog heads so I guess I don't know the answer to that question. If the Bulldog heads have MW ports in stock locations then it would work.
[Re: moparniac]
#534340
11/23/09 05:29 PM
11/23/09 05:29 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
I'm not suprised the 2d held it's own and I'll bet the torque in the 3000-3500 range was stronger compared to the 337. at 4100 pounds I'd that torque curve and take the one that averages best from the bottom of your high gear cruise RPM to your shift recovery (4 speed) or flash RPM... as close as they are up top whichever one averages higher is probably going to ET a heavy car the best. What I was saying about the 180 degree plenums and more potential is that to make 710 on the dyno the "good" plenum may be making (1/2 of) 730 and the "bad" plenum only (1/2 of) 690 so you average 710 because basically 4 of the holes are not getting fed as well and not pulling their potential weight up top.....people would kill for another 20-30cfm out of their heads (~4 cfm is potentially 1 hp per cylinder) and ideally for max power your manifold should outflow your intake port by several percent. as I remember the best to worst is about 35 cfm so the split might be even more, no way to tell unless you read thermocouples off each cylinder. Also remember that a dual plane almost always wants a larger carb to compensate for the fact that it really only "sees" 1/2 the carb as oposed to a single where each runner has all 4 barrels available to it. That why my 2d is coming off, to see if an 1150 dommy can be bridgeported to fit and open up the plenum even more (which can have a similar volume effect as adding a spacer), it should be fun and stealthy. If they're that close I might stick with the 2d....being I've got "only" 517 puny cubes But now I know I suspect I might as well go all out on the 337 port job to see much of a difference on my combo. What's really intriguing is that the 440-2 Big Single didn't really gain all that much showing that it really needed more Compression to show it's hand.....cubes alone weren't really enough. If we compare the 572 to Brian (Old School's) 13.5 :1 numbers with a similar cube motor it makes for an interesting comparison. I think my heads are on par but I got a lot less lift and and 55 less cubes and my cr (11.87:1 calculated) is right dead in the middle. Great info!! Thansk to both of you for all the hard work and sharing the data!! Needless to say some Coke bottle B bodies are packing some serious punch around here! huh??
[Re: Streetwize]
#534342
11/23/09 09:50 PM
11/23/09 09:50 PM
Posts: 16,925 NC
440Jim
NC
That is why I asked about the cam duration, perhaps it is short to go with the CR and limiting higher rpm horsepower.
[Re: BDS871Cuda]
#534343
11/23/09 10:01 PM
11/23/09 10:01 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Wow, 4100 lbs, you must have the spare tire and tool box in the trunk. I would bet low 10,s with that much HP & TQ.
Next will be the idea spinning in your head, maybe just a little juice to hit that 9 sec zone once. That's if it doesn't make it on just the motor. Have fun on the street, and buy stock in a tire company!
I think what you mean is have Rob drive to get into the 9's. There is no tool box in the trunk, just in the drivers seat.
Ron, congrats on the numbers. I know you've worked long and hard to get this combo figured out. Cuda's( ) to you, Duane and whomever helped you get it right. Streetwize, man you've got some great info. Same with AndyF. I am glad it'll all fit under the hood! Ron, are you sharp-shooting for 10.oooo's? Sounds like you will be closer than before. Great winter upgrades for sure. Congrats. I admire you, for one reason, you work hard on paper first. You use a lot of knowledge and figure it out before buying parts. You say luck....We know better. You got a lot of know how in that semi-pro football skull of yours. Congrats. Rico Maybe while Duane has it, seeif he can fab up and install a crank-scraper.
Oh ya, we in the "Lower Canadian Heights" down here, have something called Thanksgiving. I wish you and your Charger a happy one.. You are cordially invited if you want to come down for turkey . I'll pay for 3/4 the Diesel..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: AndyF]
#534346
11/23/09 11:36 PM
11/23/09 11:36 PM
Streetwize
Weddington, N.C.
Jim, yeah I wondered that too and a lot of times more cam will help a lower compression motor "hang-on" longer, you'll notice the HP doesn't keep gaining dramatically above the torque peak but does a real good job of hanging on to the torque which is an awesome build for the way Ron's gonna drive it. What you don't want (i.e., a textbook Under-cammed stroker) is the torque to peak early and then start dropping and hammering down the power curve which happens even faster as the cubes go up. I've always found the better the heads you can be a little conservative with the cam and the motor will still make really good upstairs power....by conservative I mean how much bottom end/lower middle are you realistically willing to live without....it depends on your definition of Streetable. The torque is massive and wall to wall and realistically in a 4100 pounder and a very long 4.50" stroke (already hitting 4000 ft/min at only 5300) you don't need to put all the power way upstairs, with good heads and induction the motor can hang comfortably up high without much noticable VE drop or slowing of the RPM...it's also a nice safety cushion...you know you "OUGHT" to be shifting sometime soon without worrying about the tach climbing too high or the motor laying down, like wise it's not as critical that you hit precisely the right shift point for the car to ET, you're more concerned about the hook. What's more impressive is that was a 4150, and 700 with an 850 is going to be super responsive. I agree a dominator would likely raise the torque peak (less pressure drop) but for 90% of street driving I don't know if it'd be worth the extra gas...like I said cup cars make 830+ hp and they're limited to a 4150 base carb
[Re: Streetwize]
#534347
11/23/09 11:52 PM
11/23/09 11:52 PM
Awesome, Ron......that bear is making some BIG poop......Looks like you're going to be having a LOT of fun with that thing.... That conservative motor might get you car into the 9's if it weighed 3,200LBS....... Wayne
[Re: JACKSON]
#534349
11/24/09 01:58 AM
11/24/09 01:58 AM
Posts: 2,637 Western Michigan
68Fastback
Western Michigan
great build. i want a PRH motor too! is there a long waiting line to get one done by PRH?
Dwayne does great work as you can see, give him a call he will give you straight scoop.
Nice Charger and with Dwaynes motor will be alot of fun. Good luck.
[Re: 440Jim]
#534351
11/24/09 09:42 AM
11/24/09 09:42 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
1st dyno pull with 337 intake and QF 1050:
720tq @ 4500 690hp @ 5500 . . . Just got off the phone with Dwayne....final numbers with the re-tuned QF 1050 carb ;
721tq @ 4500 705hp @ 5600 > 694hp @ 6000
Ron
Nice carb tuning results! Ask Dwayne what the final A/F was, from the 1st dyno sheet I see 13.2 at peak hp.
Jim, Dwayne leaned out the QF 1050 and got low 13 a/f throught the powerband which made the difference. It will need some attention to the squirters but i'll tune that in the car.
The cam is a .660 lift roller 266/272 on a 110 lsa. Not overly agressive lobes with street friendly spring pressures : 250 seat/600 open.
Ron
#534352
11/24/09 09:46 AM
11/24/09 09:46 AM
firefighter3931
Ontario,Canada
Wayne
Thanks Wayne....i'm very happy with my "conservative" PRH bullet !
Dwayne is the MAN !
Thanks for the Kudos to all those who posted....but Dwayne deserves all the credit here. I picked out the intake manifold and he did the rest.
Ron
#534353
11/24/09 11:32 AM
11/24/09 11:32 AM
Posts: 16,925 NC
440Jim
NC
Ron
I think this will be an awesome street/strip engine in your car. Nice to drive and powerful too.
