Re: Stock 904 okay behind mild 340?
[Re: derekeh]
#534257
11/23/09 09:49 AM
11/23/09 09:49 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
As long as you idle around you'll be fine ... There's a reason the factory didn't put the 904 behind a STOCK 340, which you do not have, even when they finally put it behind a 360 it was a beefed up version. But go for it and let us know how it works out ...
[Re: derekeh]
#534259
11/23/09 09:55 AM
11/23/09 09:55 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
It should be fine, 904s are alot stronger then some may think, i've tore up a few 727s behind 340s, but in my 360 magnum dart, it'll retain the 904 that came in it, when or if it goes, i'll just just beef it up some, I had a 73 Swinger with a very stout 370 cu. with a built up 904 & Kevlar bands/cheetah VB, it was a killer tranny & laughed at that 370, so if your 904 is in decent shape (even stock), drop it in & don't sweat it.
[Re: derekeh]
#534260
11/23/09 09:58 AM
11/23/09 09:58 AM
JohnRR
U.S.S.A.
Yeah maybe itd be a waste of time
Ifit's only for a short time and you think before you shoot then you could probably still drive it , but if you are going to put it in and beat the snot out of it then , you'll be pulling it back out sooner than you think.
I know on my Dad's 72 duster with the 318 , as soon as I installed headers on it, put in an 8 3/4 with 3.23's and started beating the snot out of it , 17 yr old that just got his license, the 904 didn't last long ... the 7 1/4 took a dump first. Granted I doubt he ever had the fluid changed and the car had about 80k on it when I got my license .
[Re: derekeh]
#534267
11/23/09 04:04 PM
11/23/09 04:04 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
and advantage of the 904 is a lighter mass rotation as far I have known...
Of course thats it could be a weak point if we talk about a heavy bracket car, but not on a mild car
[Re: JohnRR]
#534270
11/23/09 06:23 PM
11/23/09 06:23 PM
yup. 904's in heavy cars with some power not a good idea. unless you like shredded floorboards and your girlfriend beating on you saying [Edited by Moparts - Family Friendly Site - Keep it clean]..
[Re: 70AARcuda]
#534272
11/23/09 08:56 PM
11/23/09 08:56 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I ran 10.80s in a 63 Dart for 7 years with a 360 and a 904. Never had one problem with it
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 70AARcuda]
#534274
11/23/09 09:32 PM
11/23/09 09:32 PM
have yet to see a 904 come apart like a 727 ...been drag racing with the same 904 for 15 yrs. it has been rebuilt once in that time frame...because ring gear broke and took out rear spraq...and i have been using a trans brake on that 904 for 15 yrs...
see 69 barracuda in signature
71 dart in signature has 904 with transbrake with 3 seasons on it..
and these are 904 with aluminum plantaires...not the 999 steel one...
and i rebuilt both of them...and i am no expert.
HEAVY cars. lets here how many people use stock or the usual hop-ups 904 trannys in say a 71 roadrunner, or a 68 charger. with a 300hp/340cid or better engine.. like already stated above. theres a reason why MoPar never put those in there performance lineup. Darts and A-body barracudas depite what you may think, are not heavy cars.
