anyone with lm-1 with rpm converter? #533571
11/22/09 04:49 PM
11/22/09 04:49 PM
Vancouver, WA
MoparMarq Offline OP
Vancouver, WA
Thinking about getting the Innovate LM-1 with the rpm converter attachment, LMA-2 I think it is.
I have the MP orange box set-up (under the dash). Has anyone used this with the orange (or chrome) box? And, which wires did you run from the box (or coil, or whatever) to the LMA-2.
I'd like to make sure I can get the rpm function to work properly before I stick a crowbar in my wallet for another $400.
TIA,
Marq
Re: anyone with lm-1 with rpm converter? [Re: MoparMarq] #533572
11/22/09 06:30 PM
11/22/09 06:30 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
I used the inductive clamp to get RPM readings. Had to clamp it right next to the dizzy to work properly.
Re: anyone with lm-1 with rpm converter? [Re: 500Stroker] #533573
11/23/09 01:53 PM
11/23/09 01:53 PM
Vancouver, WA
Vancouver, WA
Inductive clamp connects to rpm converter, then rpm converter into LM-1? Is that how you set yours up?
Thanks,
Marq
