We got our hemi heads back from Modern Cylinder Head.
#532935
11/21/09 08:53 PM
11/21/09 08:53 PM
Posts: 1,087 Northeast, Arkansas
Dodgeman67
Northeast, Arkansas
I just want to thank Jeff for taking care of us on these heads. As you can see they look really really good, and should make some good power. Here is the intake side with the flash light shining in it. Another one without the light. Here is the exhaust side. I do have a question for everyone, the machine marks the CNC machine marks left in the ports, would you remove them or not? Jeff said they have removed them and found no HP gain? What would you do?
Re: We got our hemi heads back from Modern Cylinder Head.
[Re: Dodgeman67]
#532936
11/21/09 09:00 PM
11/21/09 09:00 PM
Modern Cylinder Head always does beautiful work, i have no complaints at all, he did a great job on my hemi heads and would use him again.
[Re: Dodgeman67]
#532937
11/21/09 09:49 PM
11/21/09 09:49 PM
Posts: 3,528 Kauai, Hawaii
452RT
Kauai, Hawaii
What would you do?
Seems you already have your answer and yes the heads look great.
[Re: moderncylinder]
#532944
11/22/09 10:03 AM
11/22/09 10:03 AM
Posts: 16,932 NC
440Jim
NC
most nascar/prostock stuff has a nc'd int port, polished chamber and exh port,,, we never seen anything in polishing
The pro levels have money to throw at things. Polishing the exhaust should help minimize carbon build up and make it easier to clean what does build up.
Post deleted by Defbob
[Re: 440Jim]
#532945
11/22/09 10:45 AM
11/22/09 10:45 AM
[Re: rowin4]
#532947
11/22/09 12:09 PM
11/22/09 12:09 PM
Dodgeman67
Northeast, Arkansas
Very interesting topic guys. Fred that does sound very logical. And I assume that's for the exhaust as well, leave them both alone, right. Bob here is my flow sheet, not as good as yours, but should make go power. I will be posting up more of our combo later to see what yall suggest for a cam for this little engine.
[Re: Dodgeman67]
#532948
11/22/09 01:34 PM
11/22/09 01:34 PM
Posts: 3,160 L.I. N.Y. Hemi Street
HemiGreg
you dont want a polished surface at all for a car engine. the surface roughness should be such that it slightly disrupts the boundry layer of material(gas/air)flowing over it. the viscosity of said mixture needs some turblance to properly swirl down the ports and around the turns at an equal velocity. cause air mixture passing a bend creats a differential pressure at bends and would reak havoc exiting the turn if the boundry layer was too smooth. think skidding on a turn when driving too fast especially when smooth surface-well kinda. fluid dynamics is a simple principal propetry of all things that flow. the golf ball and even your hood scoop height above the boundry layer and examples. also too smooth and condensation may form and submilate out liquid gas too rich and drip. its all about press/temp/delta press/viscosity/surface finish(Ra.)
[Re: Dodgeman67]
#532949
11/22/09 01:50 PM
11/22/09 01:50 PM
[Re: moeflo]
#532951
11/22/09 04:21 PM
11/22/09 04:21 PM
Dodgeman67
Northeast, Arkansas
Ain't touching them Fred. I agree moeflo, he said they had done it just didn't see any gains on the ones they did. Just thought it was good discussion. I have learned a lot and hope others have as well.
[Re: Dodgeman67]
#532954
11/22/09 06:46 PM
11/22/09 06:46 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
What casting are those? As of now I plan to run a flat tappet cam, so those big numbers dont matter much... Looks nice Jeff..keep us informed on your progress please What have you decided to go about motor wise? Cubic Inch? Compression? Cam etc?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
