Im pulling my hair out on this one....
I got some good advice from Jim earlier but cant get him back on the phone ---SO , i thought id throw this out there for some more ideas .
98 Neon . No fuel pressure.
i installed a new pump in the old module. No pressure - so i assumed it was the regulator thats on the module.
I got a new module today and it does have a new pump already in it,
i clipped 12V to it before it went in the tank.the pump ran.
So now i have the new setup in there. No pressure at the fuel rail.The pump does run
Next i clipped on direct wires from the battery to the pump , 12V and ground. So i dont have a wiring issue.
no pressure.
i pulled the line out of the Accumulator and blew air through the whole fuel line from the rail to the acc and out of it.
blew out clean.
Next i pulled the line off the pump and ran it. It does pump fuel but not a lot---shouldnt it shoot gas at a good pressure? It kind of runs out of the line like you had a water hose running on " low to medium" .
so.... maybe this new pump is weak/ bad ?
I dont know what else it could be
can the Accumulator go bad ?
fuses are good . relay is good
the car will run for a few seconds if i shoot it with brake clean in the intake
