Re: 383 with 400/440 heads
[Re: 49wayfarer]
#531293
11/19/09 09:00 PM
11/19/09 09:00 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Who knows... my guess someone cracked an original and that's what got put on... most of the BB open chamber heads are the same with different cast numbers. Don't worry about it Edit: that late may have hardened seats (unlead friendly) so... that may explain the swap too.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: 49wayfarer]
#531294
11/19/09 09:02 PM
11/19/09 09:02 PM
RapidRobert
post the #'s for the block (casting # for the date on one side of the block and/or the (prefix) letter on the machined pad by the dist and the last # 3's on the head(s)& lets see what you got.
[Re: 49wayfarer]
#531297
11/19/09 09:23 PM
11/19/09 09:23 PM
RapidRobert
'71 (model year) eng & I believe 346's replaced the 906's sometime in 70 or 71 so I'd say all original.
[Re: ph23vo]
#531300
11/19/09 10:30 PM
11/19/09 10:30 PM
Posts: 1,183 eganville ont
440beep
eganville ont
thats a 71 400 and 71 346 heads sounds all correct to me..all 383 and 440 used the SAME HEADS! dan
9.14.70 is sept 14 70 is a 1971 383
9 14 71 1s sept 14 71 is a 72 400
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
[Re: ph23vo]
#531301
11/20/09 01:24 AM
11/20/09 01:24 AM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
Nope, not in 67............
