TTI Hemi headers Early B body #531262
11/19/09 08:18 PM
11/19/09 08:18 PM
Norman, OK
426Savoy Offline OP
426Savoy  Offline OP
Norman, OK
Supposedly you can use late B and E TTI Hemi headers on an early B body , if you change the K member out with a late B model one. I know this moves the motor back some. Does anyone know, if it will cause a clearance problem between the Hemi valve cover and firewall ? By the way, I have Schumacher mounts for the Hemi.
Re: TTI Hemi headers Early B body [Re: 426Savoy] #531263
11/19/09 08:31 PM
11/19/09 08:31 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Ball peen hammer.
Either the firewall or the headers have a fate with the ball peen hammer.
Re: TTI Hemi headers Early B body [Re: 426Savoy] #531264
11/19/09 08:40 PM
11/19/09 08:40 PM
The swap to the later K in an early B seems to work fine for bigblocks. As some have documented here, the firewall pinchweld need flattened and hammer work to the transmission tunnel will have to be performed.
The Hemi is a different story. You might want to get a copy of Mopar Muscle from a year or two back where Goldberg goes to put his HEMI in a '65 B-body using a later K. It didn't fit!
*edit*
Ok, found it:
"That night several calls and e-mails went out to ask advice from builders and owners of '65 Hemi Mopars. The responses all centered on the questionable use of the '66 K-member. everyone said they never knew of anyone using a '66-and-later K-member. A call was placed to the source of the original "use a '66 K-member" information, and he said, "I knew it moved the engine back a little." According to Schumacher, the distance is actually 15/8 inches. Nice for a drag racer who wants the rearward weight bias, is willing to hack the firewall, and who will not be using the original column cable shifter, but totally impractical for a street-driven car that is being built to resemble a factory A-990.
As the body came down over... read full caption
As the body came down over the engine, Goldberg realized there was a lot of room between the engine and the radiator support, and very little room between the engine and the firewall. The engine "fit," but not in the right location for a street-driven car.Goldberg made the decision to take a step back and use the original '65 V-8 K-member with Schumacher's Hemi mounts. That meant the tti headers would either have to be replaced by custom headers or be modified to fit. Because of the engine position, the '65 K-member needed to be notched for oil pan clearance."
More here:
http://www.moparmusclemagazine.com/techa...r_cylinder.html
Re: TTI Hemi headers Early B body #531265
11/19/09 09:30 PM
11/19/09 09:30 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
My friend has a 65 Dodge with an original K-member with Scumacher mounts and TTI's and the all around fit is good.
Joey
Re: TTI Hemi headers Early B body [Re: jake4cars] #531266
11/19/09 09:37 PM
11/19/09 09:37 PM
85086
Lil Herman
Lil Herman
85086
Joey
Were they late model headers?
Re: TTI Hemi headers Early B body [Re: moparpollack] #531267
11/19/09 09:46 PM
11/19/09 09:46 PM
Norman, OK
426Savoy Offline OP
426Savoy  Offline OP
Norman, OK
Sounds like it could be a challenge with late model headers.
Re: TTI Hemi headers Early B body [Re: 426Savoy] #531268
11/19/09 11:05 PM
11/19/09 11:05 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
This is the question......... (I know this moves the motor back some. Does anyone know, if it will cause a clearance problem between the Hemi valve cover and firewall ?)
