Help identifying a radiator please #529920
11/18/09 05:21 PM
11/18/09 05:21 PM
Eyewa
330Scott Offline OP
330Scott  Offline OP
Eyewa
My white book is 16 years old & doesn't list this old radiator that I have laying around. I'm guessing that it is a '69 or '70 era rad, but that's about as close as I can guess.
If anyone could help ID it, I would sure appreciate it.
Thanks,
Scott
2949086
Re: Help identifying a radiator please [Re: 330Scott] #529921
11/18/09 06:07 PM
11/18/09 06:07 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
Just google Mopar Radiator Numbers and it will take you to a couple of sites that have all the numbers and applications from 1962 thru 1972 +/-
Re: Help identifying a radiator please [Re: Mopar Grandpa] #529922
11/18/09 06:32 PM
11/18/09 06:32 PM
Eyewa
330Scott Offline OP
330Scott  Offline OP
Eyewa
Thanks, I just tried your suggestion and the only link that gave any type of info was Roseville Moparts. And their listing appears to be either identical or close to identical to my white book. So no go at Roseville.
A few broken links and a Tripod site tried to put a virus onto my PC, plus the rest of the sites looked suspect as well.
Maybe someone has a parts interchange manual that they could look the number up?
Re: Help identifying a radiator please [Re: 330Scott] #529923
11/18/09 07:23 PM
11/18/09 07:23 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
It appears all 2949 XXX radiators are 1969, for some reason the trailer towing radiators do NOT show up on lists.
BUT - I bet it is a truck piece or incorrect/transposed numbers?
What is it 22" or 26"?
Re: Help identifying a radiator please [Re: 6bblgt] #529924
11/18/09 07:52 PM
11/18/09 07:52 PM
Eyewa
330Scott Offline OP
330Scott  Offline OP
Eyewa
I double checked the numbers when I wrote them down, so I don't think I transposed any and am pretty sure it is a 26" radiator, but didn't think to measure it. Probably should do that.
I'm not sure exactly where it came from, but it is in pretty good shape. Thinking it may have been in front of a cast crank 440 that had been transplanted into a '67(?) Polara somewhere along the line. It does have tranny coolant line fittings.
Thanks for your tips on this.
