Re: 383BB mopar in 72 duster
[Re: MrFoFody]
#528499
11/17/09 08:15 PM
11/17/09 08:15 PM
lol,yeah im gonna have fun with that,.....i sat the motor in the car today to see how it was gonna fit,the stock slant six k member is acually working,but im gonna get some front motor plates,the motor mounts are to complicated....what kind of rear end should i use?i was think a 9inch norrowed or maybe a narrowed 8.8,the stock wont hold this motor i know
#528500
11/18/09 12:26 AM
11/18/09 12:26 AM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
#528501
11/18/09 12:08 PM
11/18/09 12:08 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
its supposedly built....440 ported and polished heads,509 mopar cam,trw pistons .30 over.roller rockers.edelbrock performance rpm high rise intake,tci build transmission,2800-3000 stall converter,some where along that line
I would degree the cam before you install it! that cam loves advance from straight up spec and hates retard form straight up spec. the straight up spec is 106 intake install (max lift or intake centerline) I would put it at 102 with that TQ and less than 10.5 to 1 compression.
Flow bastards are noisy I would go with Dynomax ultra flows and an X pipe!
[Re: Dodgem]
#528502
11/18/09 12:43 PM
11/18/09 12:43 PM
Posts: 4,788 Holland MI Ottawa
2boltmain
Holland MI Ottawa
According to BigBlockDart.com its very possible to use run of the mill 1 3/4" headers on a 383/400 in an A body. Not on a 440 but a 383/400.
Keep old mopars alive.
[Re: 2boltmain]
#528503
11/18/09 02:34 PM
11/18/09 02:34 PM
Jim_Lusk
Fresno, CA
Supposedly it's Hedmans only and certain part number.
