Are Stainless bolts strong enough to hold motor plate? #528306
11/16/09 05:09 PM
11/16/09 05:09 PM
Newark, OH
Hunted Duck Offline OP
Newark, OH
Was just curious if stainless steel bolts were strong enough to hold my water pump to motorplate to engine? Thanks
Post deleted by Defbob [Re: Hunted Duck] #528307
11/16/09 05:11 PM
11/16/09 05:11 PM
Re: Are Stainless bolts strong enough to hold motor plate? #528308
11/16/09 05:16 PM
11/16/09 05:16 PM
Newark, OH
Newark, OH
Thanks...lol. I should be ok then.
Re: Are Stainless bolts strong enough to hold motor plate? [Re: Hunted Duck] #528309
11/16/09 05:23 PM
11/16/09 05:23 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
hey Jeff all ARP 12 point polished SS.....Cuz there purty
Re: Are Stainless bolts strong enough to hold motor pla [Re: Hunted Duck] #528310
11/16/09 07:08 PM
11/16/09 07:08 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Not all stainless bolts are the same quality. Just fyi
Re: Are Stainless bolts strong enough to hold motor pla [Re: 70blackfish] #528311
11/16/09 07:10 PM
11/16/09 07:10 PM
Az
Crizila Offline
Crizila  Offline
Az
Go with grade 8 bolts - what ever kind you use.
Fastest 300
Re: Are Stainless bolts strong enough to hold motor pla [Re: Crizila] #528312
11/16/09 07:29 PM
11/16/09 07:29 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
The stainless bolts you buy at your local hardware store are not very strong at all, I believe you should stay away from them. Now if you're talking ARP all of their stuff should be quality.
Re: Are Stainless bolts strong enough to hold motor plate? #528313
11/16/09 07:57 PM
11/16/09 07:57 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes, as long as your engine makes less than 4,000 hp.
For sure.
Re: Are Stainless bolts strong enough to hold motor plate? [Re: Hunted Duck] #528314
11/16/09 08:00 PM
11/16/09 08:00 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I'm one of the few who aren't a fan of stainless steel bolts PERIOD!
Into an iron block sure, but involve aluminum or a stainless steel nut in any way.... and I run, and don't look back!!!!!!!
CrAzYMoPaRGuY
Re: Are Stainless bolts strong enough to hold motor plate? [Re: Challenger 1] #528315
11/16/09 08:01 PM
11/16/09 08:01 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
For sure.
Depends on the bolt.....4 of them can hold an engine on the firewall on C130...4 BIG ones..
71 440-6 4spd & 69 Hemi 4spd
Post deleted by Defbob [Re: hemi_doug] #528316
11/16/09 08:05 PM
11/16/09 08:05 PM
Re: Are Stainless bolts strong enough to hold motor plate? #528317
11/16/09 08:08 PM
11/16/09 08:08 PM
Cincinnati, Ohio
Cincinnati, Ohio
On my old (now HEMIFRED's) Duster, I had a one piece motor plate with a Meziere water pump, held together by 6 stainless steel socket cap screws from Lowe's. Block is an iron Megablock. Hung together with no issues for 5 years. And than blown Hemi was heavy!
I held my blown 3000 HP hemi in my TAD with less!!
It's only a water pump and motor plate, it ain't like were talking a rod or something!
Re: Are Stainless bolts strong enough to hold motor plate? #528318
11/16/09 08:23 PM
11/16/09 08:23 PM
Canada
Canada
If you had an ALUMINUM block would you have still installed the stainless hardware?
I've seen so many galled aluminum parts- even with anti-seize attempts- with stainless fasteners I am now officially a scare-D-cat.
CrAzYMoPaRGuY
Re: Are Stainless bolts strong enough to hold motor plate? [Re: CrAzYMoPaRGuY] #528319
11/16/09 08:30 PM
11/16/09 08:30 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
white lithium grease or never sieze will help solve that problem, we use sst fastner's every day, mostly aircraft quality 316/316L grade , some 304 grade but the material is softer and has less chromium and will actually rust(corrode).
Re: Are Stainless bolts strong enough to hold motor plate? [Re: dartman366] #528320
11/16/09 08:46 PM
11/16/09 08:46 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I've twisted off a few SS bolts, Anything from a hardware store scares the crap out of me! I have to use SS hardware on my boat, I always thought SS was hard metal until now..
Re: Are Stainless bolts strong enough to hold motor plate? [Re: Dos Snails] #528321
11/16/09 10:11 PM
11/16/09 10:11 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Just hard to cut because it work hardens. Use anti-seize with any bolt that screws into aluminum not just SS. SS bolt will gall onto a SS nut so anti-seize or loc-tite is a good idea there too.
Post deleted by Defbob [Re: CrAzYMoPaRGuY] #528322
11/16/09 10:36 PM
11/16/09 10:36 PM
Re: Are Stainless bolts strong enough to hold motor plate? [Re: Hunted Duck] #528323
11/16/09 11:50 PM
11/16/09 11:50 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
In shear and tensile strength, a grade 5 bolt is 3 x stronger than the same sized SS bolt at the hardware store. a Grade 8 is 4 x stronger.
8.30's @3400 lbs
Re: Are Stainless bolts strong enough to hold motor plate? [Re: 340RICK] #528324
11/17/09 12:50 AM
11/17/09 12:50 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
They do look nice - they should for the cost. The bad thing about them is you have to use 12 point wrenches/sockets. A hex bolt can be tightened by 6 or 12 point tools.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Are Stainless bolts strong enough to hold motor plate? [Re: Hunted Duck] #528325
11/17/09 01:42 AM
11/17/09 01:42 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I'm using CAT bolts on my motor plate
minimum tensile strength of 150,000 psi, not too pricey and Made in USA
ARP stuff is 170,000 psi and nice looking but expensive
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
