Re: Are Stainless bolts strong enough to hold motor plate? [Re: 340RICK] #528326
11/17/09 08:50 AM
11/17/09 08:50 AM
Newark, OH
Hunted Duck Offline OP
Newark, OH
hey Jeff all ARP 12 point polished SS.....Cuz there purty
They sure are Rick
Re: Are Stainless bolts strong enough to hold motor plate? #528327
11/17/09 09:53 AM
11/17/09 09:53 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
On my old (now HEMIFRED's) Duster, I had a one piece motor plate with a Meziere water pump, held together by 6 stainless steel socket cap screws from Lowe's. Block is an iron Megablock. Hung together with no issues for 5 years. And that blown Hemi was heavy!
If you had an ALUMINUM block would you have still installed the stainless hardware?
I've seen so many galled aluminum parts- even with anti-seize attempts- with stainless fasteners I am now officially a scare-D-cat.
Apply Never-Seize liberally on the threads. Better yet, use studs instead of bolts. Drive them in slowly to reduce heat and friction.
What does "galling" mean??
Re: Are Stainless bolts strong enough to hold motor plate? [Re: Hunted Duck] #528328
11/17/09 10:06 AM
11/17/09 10:06 AM
StewartP Offline
Mopar Vintage Picture Guy
StewartP  Offline
Titanium studs
Re: Are Stainless bolts strong enough to hold motor plate? [Re: StewartP] #528329
11/17/09 10:57 AM
11/17/09 10:57 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Titanium studs
Talk about overkill.
Re: Are Stainless bolts strong enough to hold motor plate? [Re: Evil Spirit] #528330
11/17/09 11:38 AM
11/17/09 11:38 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Just as there are different grades of steel bolts there are also dofferent grades of stainless. If you're replacing a grade 5 steel bolt with stainless, be smart enough to do some research and use the same grade or better in stainless. "Research" means more than just asking for an opinion on Moparts!
Someone meantioned tensile strength. It doesn't take anything more than a calculator to figure out that if you use a big enough grade 3 bolt it will outperform an smaller grade 8! So where possible, increasing the size can solve your problem.
In your case the majority of the force will be in "shear". What's important is the fit of the motor plate and the hole size. If the bolt holes are sized properly to the bolts and there's no side movement then the clamping resistance of the water pump, block, etc. will all contribute to the strength of the coupling. But if there is slack in the bolt holes then all bets are off. With three bolts per side in the block and everything fitting properly you could probably use grade 3 bolts in there and they would never be a problem!
Re: Are Stainless bolts strong enough to hold motor plate? [Re: Stanton] #528331
11/18/09 02:51 AM
11/18/09 02:51 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
They used to attach the engines in top fuelers with hose clamps on hte frame rails; there isn't that much force that it would require anything special. I have used Stainless ARP bolts about everywhere in our aluminum engine. Neverhad galling problems, but they tend to loosen every once in a while, mainly intake/exhaust/oil pan bolts. Don't know if that's because of the material or something else though.
Plynouth VIP '67 TT IC EFI
Re: Are Stainless bolts strong enough to hold motor plate? [Re: jyrki] #528332
11/18/09 06:13 AM
11/18/09 06:13 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I use regular Stainless Bolts. I hate the steel bolts because they rust and look terrible after a couple seasons. There is an awsome hardware store in Westerville called Roush they have one of the best hardware selections I've seen locally.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Are Stainless bolts strong enough to hold motor plate? [Re: BobR] #528333
11/19/09 05:11 PM
11/19/09 05:11 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...stainless steel is just mild steel with nickel added for corrosion protection.
nickel is soft
buy your fasteners according to their rating. this will be stamped on the head 3 marks for grads 5, 5 marks for grade 8 etc.
you can get a grade 8 stainless steel bolt..the base steel would have a high carbon content for the grade 8 rating(making it very hard and strong)the nickel will just make it corrosion resistant.
hth.........al
Re: Are Stainless bolts strong enough to hold motor plate? [Re: RylisPro] #528334
11/19/09 09:22 PM
11/19/09 09:22 PM
Az
Crizila Offline
Crizila  Offline
Az
I'm using CAT bolts on my motor plate
minimum tensile strength of 150,000 psi, not too pricey and Made in USA
ARP stuff is 170,000 psi and nice looking but expensive
That's a grade 8 bolt manufactured by Lake Erie ( LE ) - a top quality fastener manufacturer in the US. Cat just had Lake Erie put their logo on them. All LE fasteners have rolled threads verses threads cut in to the bar stock. If the bolt has 6 hash marks on it ( denoting grade 8 )along with the LE trade mark, you have top quality stuff.
Fastest 300
