Alternator wiring question>> #527408
11/16/09 12:35 AM
11/16/09 12:35 AM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Im upgrading to a 100 amp alt from the stock 60 amp unit. DO i need to change any wires to a larger size?? Im thinking this is just a straight forward bolt in
....BAD A$$ STREET CAR.....
Re: Alternator wiring question>> [Re: n20mstr] #527409
11/16/09 01:17 AM
11/16/09 01:17 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
look at what the stock wire is rated and compare that to the needs of 100 amps. Plan on buying an 8 or 10 wire. and fusible link.
I want my fair share
