oil leak from head gasket ? #526865
11/15/09 06:00 PM
11/15/09 06:00 PM
Anonymous OP
Anonymous OP
is it possible to get a small drip of oil from between head gasket.cometic head gasket 528 hemi.
seems to drip 1 drop every 30 seconds,1 small drip from #1 cylinder area hits my header./
Re: oil leak from head gasket ? #526866
11/15/09 06:37 PM
11/15/09 06:37 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Is this from the oil return hole? I sprayed mine with Hylomar Blue. Last time I used Fel-pros and they leaked like a pig.
Do you have the correct surface finish. Head and block have to be very smooth for these gaskets to work properly
Re: oil leak from head gasket ? [Re: torkrules] #526867
11/16/09 08:49 AM
11/16/09 08:49 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
This is most likley from the oil drain back holes located on the front and back corners of the head. I had a customers car with cometics leak badly in this area. I would try to retorque and see if it helps. Both my engines with felpro's never had this issue.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
