Holley Accelerator pump tuning #525953
11/14/09 05:13 PM
11/14/09 05:13 PM
Costa Mesa, CA
chache876 Offline OP
Costa Mesa, CA
I have a holley 650 carb vac. secondaries. I have a bog coming off idle and have read I need to adjust the accelerator pump arm.
I'm a little confused on what I actually need to adjust. From my understanding I need a .015 clearance between the accel. pump arm and the linkage on the carb (part with the nuts and spring) @ wide open throttle correct?
It doesn't seem to matter how much I loosen that nut at the top of the spring I can not get any feeler gauge in there. The accel pump arm is fully bottomed out at WOT.
Am I doing this wrong or what?
Re: Holley Accelerator pump tuning [Re: chache876] #525954
11/14/09 09:59 PM
11/14/09 09:59 PM
Costa Mesa, CA
Costa Mesa, CA
bump
Re: Holley Accelerator pump tuning [Re: chache876] #525955
11/14/09 10:03 PM
11/14/09 10:03 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
bump
You may need to bend the arm slightly. Is it a 30cc pump or 50? Is it possible you have a 30cc pump and a 50cc cam? You can use 30cc cams on a 50 but not the other way around.
As for your bog, did you check the float level? Also, is more than .060" of the transfer slot showing (primary or secondary or both). This needs to be sorted out before you change shooters or cams.
Re: Holley Accelerator pump tuning [Re: chache876] #525956
11/14/09 10:12 PM
11/14/09 10:12 PM
Raleigh, NC
Y
Youngblood Offline
Youngblood  Offline
Y
Raleigh, NC
Well, first off, you need to tighten that nut, not loosen it in order to get that .015 clearance. By tightening it, you will shorten it's effective length. You want to get your idle speeds,actually, all base settings, done first. Then loosen the nut so that the pump cam is just touching. You have probably(almost definitely)ruined that pump diaphragm. No big deal to do another one,though
Re: Holley Accelerator pump tuning [Re: chache876] #525957
11/14/09 10:14 PM
11/14/09 10:14 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
with the throttle blade wideopened and you pressing the pump lever down.or fully compression..there should be .015 clearance...
also...if you move the throttle ...the pump should squirt...
Tony
70 AARCuda Vitamin C
