318 poly guru's #524014
11/12/09 11:15 AM
11/12/09 11:15 AM
Hannibal, MO
gtx_gts1969 Offline OP
super gas
super gas
Hannibal, MO
I have a 66 D100 with the original poly motor and wanted to know what cam kit you would recommend (cam, lifters and pushrods). Is my motor a solid or hydraulic lifter set up? I'm not very familiar with the inner workings of this motor, so any help will be greatly appreciated
-------------------------------------------- 1966 Dodge D100 short wide bed / 318 / 3spd Retired US Air Force MSgt (E-7)
Re: 318 poly guru's [Re: gtx_gts1969] #524015
11/12/09 11:20 AM
11/12/09 11:20 AM
Chesapeake Va
BobK Offline
BobK  Offline
Chesapeake Va
Contact Gary Pavlovich at glpavlovich@cox.net
he will hook you up!
1964 Plymouth Fury x 2
1964 Plymouth Sport Fury
Re: 318 poly guru's [Re: gtx_gts1969] #524016
11/12/09 11:34 AM
11/12/09 11:34 AM
Andrewh Offline
Andrewh  Offline
all poly's were mechanical/solid lifters with adjustible rockers.
Gary would be the one to contact, as all new cams would have to be custom for the poly.
Most regrind the originals.
Re: 318 poly guru's [Re: Andrewh] #524017
11/12/09 12:25 PM
11/12/09 12:25 PM
Hannibal, MO
super gas
super gas
Hannibal, MO
Thanks for the info!
Re: 318 poly guru's [Re: gtx_gts1969] #524018
11/13/09 12:11 PM
11/13/09 12:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Chris nelson cams in the business directory
http://webspace.webring.com/people/cu/um_4409/
these guys may be some help too
http://www.1962to1965mopar.ornocar.com/welcome.html
Re: 318 poly guru's [Re: Dodgem] #524019
11/13/09 12:27 PM
11/13/09 12:27 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Camcraft also regrinds Poly cams.
Leave the gun.......take the Cannoli's....Mike
Re: 318 poly guru's [Re: mike s] #524020
11/13/09 05:38 PM
11/13/09 05:38 PM
Hannibal, MO
super gas
super gas
Hannibal, MO
Thanks again!
Re: 318 poly guru's [Re: gtx_gts1969] #524021
11/13/09 06:28 PM
11/13/09 06:28 PM
canada
jneuf Offline
jneuf  Offline
canada
I got mine through Gary. Cam and lifters (solid) came from Schneider Racing Cams, who is still grinding new poly camshafts....probably one of the only cam grinders left thats doing it...
Here is their website:
http://schneidercams.com
Re: 318 poly guru's [Re: gtx_gts1969] #524022
11/13/09 11:59 PM
11/13/09 11:59 PM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
Re: 318 poly guru's [Re: rockerbob] #524023
11/15/09 02:49 PM
11/15/09 02:49 PM
Hannibal, MO
super gas
super gas
Hannibal, MO
Thanks again
Re: 318 poly guru's [Re: gtx_gts1969] #524024
11/20/09 05:41 PM
11/20/09 05:41 PM
canada
jneuf Offline
jneuf  Offline
canada
