Ideas for a 528 hemi build, Pistons, cam, etc...
#522641
11/10/09 06:01 PM
11/10/09 06:01 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
I've been gathering parts for the hemi challenger and am ready to order pistons, rods and a cam. I have an iron world block, 4.500 bore, obtained a 4.150 crank (Thank you FY1TA), have a set of hooker super comp headers, cast iron ported heads, and a factory but ported dual quad intake. The car will be stock body and weight wise. It will have caltracs with Eddy adjustable shocks in the rear. Calvert front 90/10 shocks. I still have to get a dana and a 727 for it so the gearing is still up in the air. My goal is to have a 528 that will run on pump gas (93 octane) but still run a 11.00 all day long. What pistons (CR?), cam (manual brakes), and rods(I or H) should I get? Any other suggestions are appreciated.
Chris from New Jersey
Re: Ideas for a 528 hemi build, Pistons, cam, etc...
[Re: fig426]
#522644
11/11/09 08:35 AM
11/11/09 08:35 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
As has been said by others for the rods etc. I'm using CP pistons in mine (10:1). As for the cam, after what I've been through I don't think I'd run a hydraulic anything anymore. They are not what they used to be. At least with a mechanical you know where you stand. Roller anything will require alot of checking. There are push rod guides in the block and head, although there may not be a guide in the world block. Because the roller lifters are taller and push rods are angled. The push rods may hit the head or block or both. Some guys remove the block guide so they only have to worry about the head.
I decided to go stage V on mine and I'm getting the entire package from Tim Banning. That way if I run into trouble he can at least help me out as he knows the set up.
[Re: torkrules]
#522645
11/11/09 11:31 AM
11/11/09 11:31 AM
fig426
East Coast, NJ
Ok so 10:1 or so and H beams. Any more suggestions on a cam??
[Re: ChrisDavis]
#522648
02/23/10 10:16 PM
02/23/10 10:16 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Chris, I think we have twin engines separated at birth. My 528 Barton Hemi came in at 704hp and I think it has the same exact solid cam. I have the hardened lifters. I have the Stage V 2x4 intake and heads, Edelbrock carbs, Moroso pan... I went for the RBRE rocker system also. There are a couple of dyno links in my sig.
[Re: Vert]
#522649
02/27/10 11:31 AM
02/27/10 11:31 AM
Vert
Annapolis, MD, USA
Chris, Did you use a hemi k-frame or a BB? Which engine mounts? Thnx!
