Slide Hammer for removing the front pump? #521715
11/09/09 08:27 PM
11/09/09 08:27 PM
Newark, OH
Hunted Duck Offline OP
Newark, OH
Where is the best place to get a slide hammer to remove the front pump. Or is there a different method? Thanks
Re: Slide Hammer for removing the front pump? [Re: Hunted Duck] #521716
11/09/09 08:30 PM
11/09/09 08:30 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yea screw 2 bolts in the threaded holes and pull it out with a pry bar
Re: Slide Hammer for removing the front pump? [Re: Quicktree] #521717
11/09/09 08:35 PM
11/09/09 08:35 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I just got all thread with a round stock.with a hole drill in it. round stock is 3"x2"
Re: Slide Hammer for removing the front pump? [Re: Hunted Duck] #521718
11/09/09 08:35 PM
11/09/09 08:35 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use 2 bolts and a piece of chain,one good pull and it comes right out.
Nautilus Racing-
Re: Slide Hammer for removing the front pump? [Re: Chris2581] #521719
11/09/09 08:48 PM
11/09/09 08:48 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I just used 2 long bolts to drive it out. I know, not the preferred method but it works.
Re: Slide Hammer for removing the front pump? [Re: Chris2581] #521720
11/09/09 09:55 PM
11/09/09 09:55 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I use a bar under the chain to pop the pump out.
Re: Slide Hammer for removing the front pump? [Re: justinp61] #521721
11/09/09 10:18 PM
11/09/09 10:18 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Stand trans on bell, tap tailshaft with mallet.
Re: Slide Hammer for removing the front pump? [Re: Hunted Duck] #521722
11/09/09 10:25 PM
11/09/09 10:25 PM
NC
440Jim Offline
440Jim  Offline
NC
A slide hammer is a body shop tool and nothing fancy, cheap. You just need a couple bolts (3/8-16 on a 727) coupled to the slide hammer. The other methods do work too.
Re: Slide Hammer for removing the front pump? [Re: Chris2581] #521723
11/09/09 10:51 PM
11/09/09 10:51 PM
Cab_Burge Online work
Cab_Burge  Online Work
Sometimes it takes me two or three pulls now You can take a short piece of chain and hook it under the two bolts (that are there to be used in removing the front pump, there half way up from the bottom bolts) and use a lever to pull it out by bracing it on the other side of the bellhousing
Re: Slide Hammer for removing the front pump? [Re: Cab_Burge] #521724
11/09/09 11:23 PM
11/09/09 11:23 PM
Newark, OH
Newark, OH
Thanks for the replys I got a 904 here that is begging to be opened up!!! I got to books here I have been reading. Carl Munroe's and a stock tranny book. Good info. Thought I would tear one apart to get a better understanding.
Re: Slide Hammer for removing the front pump? [Re: Hunted Duck] #521725
11/10/09 01:17 AM
11/10/09 01:17 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
I do the same as Wild Bill,
Just thread 2 pieces of all thread in and it pushes the pump out.
They are blind holes, not through holes.
No chains,bars,or slide hammers needed.
Re: Slide Hammer for removing the front pump? [Re: demon440] #521726
11/10/09 08:41 AM
11/10/09 08:41 AM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Go to AutoZone (or local parts house) and buy a cheap dent puller. They are usually less than $10. Take the little threaded tip (that holds screw) off, and the end is male thread and screws right in front pump. There's your slide hammer.
Good Luck
Re: Slide Hammer for removing the front pump? [Re: TheBlackCar] #521727
11/10/09 03:57 PM
11/10/09 03:57 PM
south louisiana
lowell66dart Offline
south louisiana
I like to make tools. Go to the hardware store and get two long 3/8 bolts, like 8 inch if you can find them. Now you need 2 pieces of something heavy with a 3/8 hole thru the center. Round stock like someone suggested works well. Instant slide hammers.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: Slide Hammer for removing the front pump? [Re: TheBlackCar] #521728
11/10/09 04:26 PM
11/10/09 04:26 PM
Good Luck
This is what I did.
Re: Slide Hammer for removing the front pump? [Re: ] #521729
11/10/09 05:35 PM
11/10/09 05:35 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I have probably less-than 5 bux in mine .....
2 12" 3/8 bolts ... 20 or so large "fender" washers on each bolt ...
I have used this way on many MANY tranny rebuilds over the years.
Post deleted by Defbob [Re: Chris2581] #521730
11/10/09 05:36 PM
11/10/09 05:36 PM
Re: Slide Hammer for removing the front pump? #521731
11/10/09 06:27 PM
11/10/09 06:27 PM
RobX4406 Offline
RobX4406  Offline
Don't need any of that stuff to get it out.
Maybe a Mallet
Re: Slide Hammer for removing the front pump? [Re: RobX4406] #521732
11/10/09 06:51 PM
11/10/09 06:51 PM
Newark, OH
Newark, OH
Thanks guys. I am going to try a few of these suggestions tomorrow. Didn't get a chance today as I was working on replacing my diagonal link.
Re: Slide Hammer for removing the front pump? [Re: RobX4406] #521733
11/10/09 06:53 PM
11/10/09 06:53 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
I use two 5/16 short studs with a slot cut in one end and thread it down into the case holes through the 2 threaded pump holes. Then use two 3/8 bolts to act like jack screws and pry the pump off evenly. Without the 5/16 studs you may deform the case threads.
Garth
Re: Slide Hammer for removing the front pump? [Re: VernMotor] #521734
11/10/09 07:03 PM
11/10/09 07:03 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I made the same thing for pulling front pumps... Mine was free, I had all the stuff laying around the garage....
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
